damp around window on recently moved into property
- python
- General Builder
- Been thanked: 7 times
I don't know what picture is which, so I'm going to post them now, then explain in the second post what you're seeing. Just got these via email.
Basically we have an exposed East face of a solid stone building.
The property owner has only recently moved in (about 3 months ago), prior to moving in, I gave the house a once over. The sides of the windows weren't very well sealed, with the mortal cracked or missing. I applied a silicone to the side of the window frame, then laid a mortar bead over the top of it. At the time there were no visible signs of damp, although who knows what the previous owners did to hide it.
As you will see there is a gap of missing mortar (possible missed by me (it's a large property), possibly newly missing) to the left of the lintel, which is timber.
It is a single glazed window.
All has been recently decorated. Walls and windows, inside and out.
I am have obviously advised the client to seal the gap to the left of the lintle. He has also applied 1 coat of weathershield to the wall.
The questions are really -
- Is this likely to have been caused by that small hole next to the lintle? The damp area is a little further away from it than I would expect.
- Why would this apparently become evident now if it's not the gap next to the lintle?
- What are the chances this is just moisture built up in the wall from the poorly seald windows previously, now trying to escape?
Most of the gouse is double glazed apart from three windows.
- jon 1 (Small).JPG (15.42 KiB) Viewed 3290 times
- jon 2 (Small).JPG (10.19 KiB) Viewed 3290 times
- jon 3 (Small).JPG (11.06 KiB) Viewed 3290 times
- jon 4 (Small).JPG (70.98 KiB) Viewed 3290 times
- jon 5 (Small).JPG (56.1 KiB) Viewed 3290 times
- jon 6 (Small).JPG (29.64 KiB) Viewed 3290 times
