Stuart turner shower pump
- Gas/Heating Expert
- Been thanked: 9 times
I removed a showermate pump this week... anyone what it? Postage may be a bit steep, as a heavy lump of pump!
- BANNED
generally thats what pumps do, though the wording of your question could be somewhat ambiguous. when you say draw UP from the tank what exactly do you mean, its generally better to have the pump located below the tank in the instances ive found.RichieP wrote:Really, really stupid question, but will that draw up water from the tank, then down and across to the shower?
if there is insufficient head to feed the shower then a negative head kit can be fitted
[url=http://www.ultimatehandyman.co.uk/diy/decking/index.htm]Decking[/url] | [url=http://www.directory.ultimatehandyman.co.uk/plumbers/]Plumbers[/url]
- BANNED
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
- Jaeger_S2k
- Pro Handyman
- BANNED
RichieP wrote:Probably is. But seeing as that's how it was when I moved into the house I'm not going to spend unnecessary money changing it.
Have you actually got anything constructive to add to this thread?
your a shirty boy arent you, we are not at home to mr rude.Dirk Diggler wrote:generally thats what pumps do, though the wording of your question could be somewhat ambiguous. when you say draw UP from the tank what exactly do you mean, its generally better to have the pump located below the tank in the instances ive found.RichieP wrote:Really, really stupid question, but will that draw up water from the tank, then down and across to the shower?
i have added constructive information richie(see above), now stop acting like your avatar
