Front Door Weather Bar
Locked
chessbandit
Post by chessbandit »
Problem with inward opening front door. Need 100mm+ weather br but all I can see on the internet is up to 75mm. Any pointers in the right direction will be appreciated. I am in the middlesex area. Thanks
Simon Site Manager
Has thanked: 48 times
Been thanked: 202 times
Post by Simon Site Manager »
Hi Chess,
Can you post a pic, I am guessing that the projection you want is 100mm?
S
chessbandit
Simon Site Manager wrote:Hi Chess,
S
Thanks Simon..............will get back to you.
Has thanked: 736 times
Been thanked: 2341 times
some weather bars are reversable as in 69x 95 they have drip channels on both edges :thumbright:
KK
Post by KK »
not sure why you would need such a big overhang .one problem to watch is fitting it /you ll have to cut an angle off or it will jam against the door frame when opening ..the bigger the overhang /the bigger the piece you need to chop ?
chessbandit
big-all wrote:some weather bars are reversable as in 69x 95 they have drip channels on both edges :thumbright:
chessbandit
S
Sorry it took so long. Simon, a picture as per your post. It is 4cm. Anyone knows a  supplier in the Harrow area I would be grateful.
weatherbar (175 x 98).jpg (5.6 KiB) Viewed 4671 times
Locked
Return to “Kitchen Fitting”
