drawer set to fit MFI base unit.
Hi everyone,
I am having a problem with my DIY, so typed a couple of words into my browser & found this very interesting forum.
I bought some MFI kitchen units from another store after MFI closed down. I bought a nomber of base & wall units, including a 500mm. four door drawer set. That was two or three months ago now. Having now started fitting them, I now find that the packing only includes the fronts, not the drawers themselves. I tried to get them from B&Q, but was informed that their drawer sets would not fit into the MFI base unit as the opening is 8mm. different " thickness of the timber".
The measurements of the opening of my base unit is.... 465mm. wide.
685mm. high. It has four drawer fronts, the bottom one deeper than the other three.
Does anyone know where I can purchase them.
Regards,
jcub.
Regards,
jcub.
- Has thanked: 823 times
- Been thanked: 3559 times
The way around this is to buy these http://www.screwfix.com/prods/16005/Kit ... m-400-86mm
You make the back and base out of White Melamine chipboard which is cut to suit the width allowing for the runners.
Do the job for you and cheap Screwfix do not have them in at the moment but you can find them on other suppliers by searching.
- Has thanked: 7 times
- Been thanked: 19 times
Re: drawer set to fit MFI base unit.
jcub wrote:Hi everyone,
How old is your MFI kitchen. Only, I was under the impression that Shrieber or Hygena were their suppliers prior to them going bust.
Trevor
Hi Trevor,
I bought the units six months or so ago, after MFI went bust. They were being sold at a store just out of Doncaster called "RANGE" for around a third of the original price. They have been waiting in the garage for the winter to arrive, and it certainly did!!!
I will check out Shrieber & Hygena and see what they can come up with.
jcub.
jcub.
