1144 Alloy (Stressproof)
BigGK
Post by BigGK »
Hey everyone
I am looking to make a barbell and some dumbells out of the above alloy.
I have done a fair bit of research and have found the 1144 alloy to be very strong (compared to mild steel).
I cant find it anywhere in the uk, does anyone know of stockest in the uk that would do small quantities e.g. 6m? Or can anyone recommend adifferent type of steel product, that would suit the job?
Thanks for taking the time to read this post
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
I would guess thats not a European standard number, American probably.
Looking it up, strength of 115,000psi is pretty hard stuff.
That equates to about 80kg/mm2, normal mild steel is about 50kg/mm2.
I suppose you'd want something like EN24...
http://westyorkssteel.com/EN24.html
BigGK
Post by BigGK »
Cheers Hitch
I had a look at the web site, I have heard that heat treated steel is more likely to snap than bend, just wondered if I should be concerned about dropping the bar with weights attached?
Could anyone point me in the direction of a simple safe working load calculation?
e.g. weights on each end of a bar, while picking it up in the centre.
Cheers for all your help :thumbright:
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
For the barbell I think you would be better off buying a ready made bar. When you get a couple of hundred pounds on an olympic bar it bends a fair bit.
As you have mentioned heat hardened steel is hard, but is brittle and will not flex.
Last edited by ultimatehandyman on Wed Feb 10, 2010 6:12 pm, edited 1 time in total.
BigGK
Post by BigGK »
Cheers both for the response
Have decided to buy a olympic barbell set
