Tiling around bathtub
- cameradoctor
Hi all,
I am about to tile the walls in our ensuite, and wondered what the best procedure around the top of the bathtub is?
At this stage the builder has inistalled the tub, and used the correct water resistant drywall board down to the tub, and I am about to put tiles on that - should I be doing anything special regarding sealing where the tile meets the tub?
TIA
Greg
TIA
Greg
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- cameradoctor
thescruff wrote:I would run a bead of silicon around the drywall before you tile and again after you have tiled to finish and seal the join.
Thanks,
Do you mean at the bottom of the drywall, behind the tile, or between the bottom of the drywall and the top of the tub?
The 'after' bead goes between the tile and the tub ?
TIA
- thescruff
- cameradoctor
Help with silicon residue!
Ok,
This tiling job is nearly done - was putting the silicon sealer around tub and expansion joint around the walls, and I managed to get some residue from my dirty rag onto the floor tiles ( Porcelain )
It is residue from the excess sealer!!
It has made the floor very slippery - I tried lots of elbow grease while it was still wet, but to no avail!
Any tips as to what i can use to clean this off ? Acetone or Alcohol maybe ??
Help
Help
