Kitchen Hinge Measurments
Locked
andysubaru3089
Post by andysubaru3089 »
Hi Guys,
To start with, I am a newcomer to this forum and hope to use this forum alot in the future.
I dont if this has been asked already but when marking out to fit a kitchen hinge, how do i figure out where to drill my hole. Do i have to set the hinge to its max settings or min settings. Is there any websites that would show me.
Hope you guys can help
Cheers
Andy
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Do you mean marking it out to fit on cabinet or to fit onto the door?
Has thanked: 825 times
Been thanked: 3574 times
Have a read of this http://www.woodfit.com/index.php?sid=82 ... &cPath=273
All the data you need
royaloakcarpentry
That link is for Blum. They are standard measurement for them, other makes can vary though.
Very handy link though, cos I like Blum hinges, aswell as hafele. I never remember the measurements so always work it out on test peice. Now I know where to go to save the working out.
andysubaru3089
I mean both, door and frame. Just want simply measurements
royaloakcarpentry
You will need to do a test peice first as your make of hinge could vary.
For centre of hole on door, measure in 23mm.
For centre of crucifix to be fitted onto frame, measure in 37mm from edge of carcass.
You must do test peice though as there are different sizes of kitchen hinges.
andysubaru3089
Right ok, what hinge is that based on and is that just a rough guide to start with
How thick is the door? This will affect the hinge mortice centre to allow the door to clear the carcase face.
There are lots of variables so the best way is to experiment on test pieces. If you fix the mounting plate end to a piece and then offer the door up you will get an idea of where it is. Some hinges allow you to make a mark through the centre point of the door mount.
royaloakcarpentry
That is based on Blum but you have other makes also. You also have different diameter cups (the part of the hinge which fits into hole in door).
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
i have 2 of these in the van and they really are a blinding tools to have! :thumbright:
http://www.wolfcraft.de/jcatalog_genera ... oduct.html
IF IT WERE EASY ITD B BORING!
Locked
Return to “Kitchen Fitting”
