Fixing Aquapanel to Wimpey Walls
- Cantseeitfrommyhouse
- Has thanked: 36 times
- Been thanked: 108 times
Has anybody come up with a quick, cost effective means of getting a plumb flat surface in aquapanel when the the substrate is an aerated block wall laid by a blind pikey with parkinsons disease??
This is a constant source of annoyance for me, as walls are never plumb or flat, and trying to tile using 500 x 250 tiles onto anything less than flat is a right ball ache.
I've read the gubbins about "aquapanel needs to be fixed to battens not dot n dabbed etc" but frankly when the bathroom has had to have the plaster notched to fit the bath in, there's no room to be throwing in stud work that shouldn't be necessary just to support the already fiendishly expensive cement board!
Not to mention of course that if the wall isn't plumb or flat the frame work is going to waste even more precious space.
The only method I can think of is using floor to ceiling 6" wide rips of WBP 12mm ply laboriously shimmed out and hammer fixed to plumb/flat at 400 centres , and then screwing the panel to that. Any takers?
The only other alternatives seem to incur huge risk of tiles falling off/damp or a 6yr wait for cement/plaster to dry out enough to tile onto
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
As I understand it ...
the stud work isn't there just to support the aquapanel. Its to allow for an airgap behind it. Aquapanel will let the water through very easily (just pour some water on it). The point of course is that it doesn't deteriorate when wet.
I just did not have the room for a stud work either so what I did is Dot and dab the aquapanel to the wall and the use fisher 60mm fixings also. The Dot 'n' Dab seems ok but I read that you cannot use the dry wall adhesive on cement based board. I don't know how accurate this statement is. The drywall adhesive is probably more use as a support & spacer behind the aquanel rather than an adhesive
I swang out of the board like a retarded ape and it was going nowhere Iam not convinced I needed the screws also but it costs little too much risk if the drywall adhesive failed.
Oh and I used aquapanel joint adhesive and joint tape then tanked the aquapanel, so a real belt and braces approach.
Work out well
Work out well
Not when it's been liberally coated in SBR. And besides if that were the case, the stud work would rot so I'm not buying that justification myself Besides, dot and dab probably provides more ventilation behind due to there being no enclosed spaces due to studs & noggins.DIY_Johnny wrote: ...Its to allow for an airgap behind it. Aquapanel will let the water through very easily (just pour some water on it).
I've used waterproof flexi rapid set tile adhesive to dot and dab cement boards up recently, and I too was contemplating using 80mm fischer hammer fixings to assist, but came to the conclusion that the fixings would have no grip on the board after drilling a hole. Some sort of galv washer would be needed, and that would jack the fixing head up into the way of the tilingDIY_Johnny wrote:
I've used scrim tape and adhesive to joint.DIY_Johnny wrote: Oh and I used aquapanel joint adhesive and joint tape then tanked the aquapanel, so a real belt and braces approach.
- Mr. Grumpy
They way I outlined it above was from aquapanel direct. Of course they stated that you shouldn't DnD and have a 38mm airgap of what he told me was his unofficial advice.
Actually yes I used fisher fixings but those square ones thaty really get a good grip. An I also used rounded Penny washer, so looks like we are doing the same thing
Probably should have used a tile adhesive rather than a drywall one as TicTic says
Regarding the stud work, they recommend metal studding, not wood so no problem if water gets through I suppose.
Ah right. Saves me ringing them then.DIY_Johnny wrote:They way I outlined it above was from aquapanel direct. Of course they stated that you shouldn't DnD and have a 38mm airgap of what he told me was his unofficial advice.
Square fixings? Do you have a link or piccy please?DIY_Johnny wrote: Actually yes I used fisher fixings but those square ones thaty really get a good grip. An I also used rounded Penny washer, so looks like we are doing the same thing
DIY_Johnny wrote: Probably should have used a tile adhesive rather than a drywall one as TicTic says
Well I hope ours both stay put :P. Can't see why it would fail, if tile adh. is fine on the wetter side of the board, should be ok on the other side. Only issue I can think of would be if the tile adhesive dabs were too thick might affect strength.
Ah, I see. Other than when it ruins the floor I guess :DDIY_Johnny wrote: Regarding the stud work, they recommend metal studding, not wood so no problem if water gets through I suppose.
- Mr. Grumpy
These plugs and screws were the ones I used. I only used penny washer cos I have a heap of them and just opened up the hole to allow for the screw to fit through
As I tanked the shower area too I can't see any water getting through and even if I didn't tank I would be that worried about it as if a grout line failed we are not talking about gfallons of water gushing through
As I say the dry wall adh did hold it but I fixed it a day later with screws so don't know if it would have failed over time.
