Removing vinyl to ceramic on concrete
Gordo
Post by Gordo »
What preperation is required to fix the ceramic tiles to concrete when there is residue left from the vinyl tiles when I lifted them. Can I just apply ceramic glue over the residue, or is there some sort of special prep needed. All advise very welcome.
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
Hi Gordo,
Welcome. Got any pictures of the floor?
Would be easier to comment as the coverage of the residue can make a difference.
What is the residue? Back of vinyl? Just the adhesive? What's the covarage?
Jaeger.
Has thanked: 807 times
Been thanked: 3498 times
I suspect it is the bitumen type glue that is a bast to remove. Usually a sealer type screed is applied over to provide a sound surface to tile on.
Keygs
Post by Keygs »
Hi Gordo
try a bit of metho mixed with turps about 50/50 on the glue, leave it for about 10 mins and see if the scrapper will take it off. I removed the adhesive from cork tiles this way on a concrete floor. The metho reacts with the glue and the trups stops it from drying out too quickly
cheers
Keygs
Only-Me
Been thanked: 3 times
Post by Only-Me »
If its just the remnants of glue......evostick type...........then just use flexi sticky and grout as normal :thumbright:
