firefox
village idiot
diesel demon
Has thanked: 104 times
Been thanked: 104 times
firefox
Post by village idiot »
last couple of days firefox has been very slow to start, eventually kicking in after about 25 mins of apparent inactivity ::b
i'm using google chrome at the moment, seems ok but while i like google i feel there is a wee global domination thing going on in the background :roll:
personal preferences i know, same as preferring AMD over intel, i'd got used to firefox & i have no intention of going back to IE if i can help it
i love being married
it's great to find that one special person that you want to annoy for the rest of your life
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Have you updated to the latest version.
Never had problems with Firefox, although the latest has an issue with flash I believe.
village idiot
diesel demon
ver 3.6
Still Yes Highland
thescruff
Post by thescruff »
Thats the latest version.
Perhaps a re-install would do the trick, the boys will be on with a few ideas no doubt.
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
VI,
If it is taking so long to initially start, clear out all the temp files and folders.
I don't know which Operating system you use but if XP or Vista:
1st thing to do is clear out all your temporary files, tool of choice is ATF Cleaner, it is free and you do not have to install it. Download and instructions here (Windows XP, 2K, 2003 & Vista ONLY)
* NOTE : If you would like to keep your saved passwords, click No at the prompt.
-- Click on ATF-Cleaner to run it
-- Where it says Select Files To Delete, Check the Select All Option
-- Click Empty Selected - > OK
You use Firefox browser, so do this also:
* Click Firefox at the top and choose Select All from the list.
* Click the Empty Selected button.
Do you have Ccleaner installed?
If so, open Ccleaner -> click the Cleaner Button on the left -> in the Applications tab under Firefox place a tick in 'Compact Databases'.
Click Analyze -> when the list appears, click Clean.
If you don't have Ccleaner, may I recommend getting it and follow these CCLEANER Setup Instructions
You could also try Speedyfox, which is so simple to use and does make a noticable difference:
Post back.
dave
But you cannot tell him much.
dave.m
Post by dave.m »
Forgot,
Before you post back, look in Tools -> Addons -> Extensions and click Check for updates. Then make a list of all the addons that you have in the list, and post it on here.
dave
village idiot
diesel demon
adblock plus 1.1.3
adobe DLM 1,6,2,48
better gmail 2 0.8.9.1
brittish english dictionary 1.19
colouful tabs 4.3
IOBitCom toolbar 2.5.6.0
java console 6.0.12
java console 6.0.13
java console 6.0.14
java console 6.0.15
java console 6.0.07
jeteye 1.8.0.20090402101040
megaupload toolbar 3.1
microsoft .net framework assistant 1.1
minimap addon 0.3.13
realplayer browser record plugin 1.0
WOT 20091028
zynga toolbar 2.5.6.0
Still Yes Highland
dave.m
Post by dave.m »
Do you use all those toolbars?
The latest Java Console is v6.0.18 so click on Check for addon updates and if you get the 6.0.18, remove all the others.
If it does not update to v6.0.18, then uninstall all the earlier ones and just keep 6.0.15.
Did you use the cleaners?
To see if it is the addons that are slowing down Firefox, start it in Firefox (safe-mode) and time its startup.
How to start Firefox in Safe Mode
1. Close down Firefox completely
2. Click Start -> All Programs list ->go to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode). Then select disable all addons.
Note: You can also start Firefox in Safe Mode by clicking Start, selecting Run (or use the Start Search box in Windows 7 and Vista) and then entering the following in the text field:
firefox -safe-mode
dave
village idiot
diesel demon
i used ccleaner, have removed old javas & the megaupload toolbar
has made a big difference
Still Yes Highland
dave.m
Post by dave.m »
You can get rid of the microsoft .net framework assistant 1.1 too!
Also get rid of the Adobe DLM. That will have come down with the last Adobe update.
To control what installs at updates go into Tools>Options>Advanced (far right), click on the 'Update' tab and select "Ask me what I want to do" below where it says, "When updates to Firefox are found:" and that way anytime an add on tries to install on your pc, you can decide whether or not to allow it.
dave
thescruff
Post by thescruff »
Firefox 3.6 has a problem with java console, and uninstalls them on boot up
dave.m
Post by dave.m »
Scruff
Where did you read that.
Mine doesn't, it is still there and enabled, v6.0.18.
dave
Screen Shot (Medium).jpg (52.65 KiB) Viewed 2133 times
thescruff
Post by thescruff »
Java console keeps trying to update, and firefox keeps uninstalling it.
Since I got the 6.0.18 it seems to have settled down, but it was a pain when firefox 3.6 first came out.
How do you get rid of all the old vers in extensions
dave.m
Post by dave.m »
What version do you have of the Java Console?
I have just clicked to check for updates , on the addon list and no updates available fro any addons but no problems.
How do I test whether Java is working on my computer?
http://www.java.com/en/download/help/testvm.xml
dave.m
Post by dave.m »
Any number of ways.
Windows Control Panel -> Programs -> Add/Remove list and uninstakll from there.
Use Revo Uninstaller if you have it installed.
Open Firefox -> Tools -> Addons -> Extensions -> click each one and click uninstall -> click to restart Firefox.
dave
VI, sorry for hijacking your thread.
Return to “Computers”
