Fixing plasterboard to plasterboard
Ted White
Post by Ted White »
not sure what "wat" means. If there's more detail or references to lab data needed, just ask.
paul the spread
Has thanked: 5 times
Been thanked: 23 times
Post by paul the spread »
i nearly fell off my chair laughing.... mass law my ars3.
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
Python i think ted maybe a yank! after reading his post that how it comes across!!!! :thumbright: and they cant plaster over there! ::b
IF IT WERE EASY ITD B BORING!
Raf
Has thanked: 1 time
Been thanked: 4 times
Post by Raf »
OP; i asked about green glue some time ago..... please can you update this post after with your opinion on its soundproofing ability?
Ted White; please may i see lab data and also can you highlight the bits relevant to the OP? thanks
GJO
Post by GJO »
Ted White wrote:not sure what "wat" means. If there's more detail or references to lab data needed, just ask.
Ted, what data do you have to show that this won't work? There simply isn't the space for building out (~30mm to the window space) so I don't really have another option.
Would Green Glue have no damping effect? Is that not its explicit function?
Ted White
Re: Fixing plasterboard to plasterboard
Post by Ted White »
I see quite a few posts. I thought I would have been alerted to new posts. Sorry for the delay.
The damping being discussed is known as constrained layer damping. It's essentially a sandwich of two layers of masswith a damping material in the center. As the wall is oscillated with a sound wave, the middle section of damping material is sheared. This shear force converts the kinetic movement of the wall into heat. You can Google all of this.
At any rate, damping is most efficient when the stiffness of the two halves of the sandwich are similar. Highly dis-similar stiffness materials don't create the shear force, therefore little damping. This is why you can't expect to directly damp a heavy masonry surface.
Regarding Mass Law, another well discussed principle you can Google at your leisure.
Return to “Plastering Forum”
