Mitre joint in lightweight worktop with cardboard middle!
Locked
gazza991
Post by gazza991 »
Hi, I am about to join my worktops together and hoping to do this by a mitre joint. My plan was to do this using worktop joining bolts but the worktop i have, has a cardboard middle and am sure thats its not going to be strong enough to use the joining bolts? Can anyone suggest how to do this another way? Have alook at the picture to see what i am on about if you dont understand. thank you
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
you have to insert a wooden tounge into both tops before routing the bolt holes, :thumbright:
IF IT WERE EASY ITD B BORING!
Has thanked: 823 times
Been thanked: 3560 times
I think you have to use these connectors for honeycomb worktops http://www.locksonline.com/acatalog/max ... -7590.html
I have no experience of these so I cannot offer any other advice
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
never even seen these before. whats the craik wif them? they cheaper or something?
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
i also have never seen this kind of top, any links/info etc
marc1106
Post by marc1106 »
alot of the thicker tops such as 50mm+ are hollow core now for weight reduction. but generally the 40mm hollow tops are just a money/green issue thing really, less material used = more profit for the manufacture, and less chipboard used allows them to make more tops with the same
amount of waste products coming in, so better for enviroment!
These honeycomb worktops are very popular in Europe, where the style is for thicker profiles. I suspect that the green reasons Marc has given above are behind the trend.
The fitting is a cam locking system that is quite clever. See page 15 in this PDF http://www.hafele.com.vn/vn/en/documents/section02.pdf
If you read on it shows you how to fit them.
I am sure that this will become more common in the UK as the thick profiles catch on.
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I had never seem them before either :scratch:
gazza991
Post by gazza991 »
Thank you for the replys. The work tops are 50mm and like someone has said its due to weight issues they are made the way they are, i popped into b&q and they said i need a eurolight fitting kit! At an extra £65! which is just what i was hoping for!!!!!
For those of you following this thread this is worth a look through. It shows the worktop jointing process and the need to buy a shiny new worktop jig with Eurolight fitting templates.
http://www.nikpol.com.au/pdfs/Nikpol%20 ... ochure.pdf
marc1106
Post by marc1106 »
or alternativly you could pack it out with timber to support exposed edges :lol:
KK
Post by KK »
you ll find these now in the uk , but generally theyre used for decor ends ? with a solid version for the actual worktop ?
You could practice on joining two BnQ moulded doors :lol:
Raf
Has thanked: 1 time
Been thanked: 4 times
Post by Raf »
dewaltdisney wrote:You could practice on joining two BnQ moulded doors :lol:
LOL :-)
Locked
Return to “Kitchen Fitting”
