Cutting a strip from a floor tile (ceramic)
Duck_Tape
Has thanked: 151 times
Been thanked: 45 times
Post by Duck_Tape »
Hi All
In the attached diagram's of a mocked up tile (sorry its a bit rough)
how do you get a clean cut from a floor tile 300 by 300 to remove a strip.
The two side cuts (1 and 2 in the image 1) are fine just run it along the diamond wheel tile cutter it the horizontal cut (cut 3 in image1) that's gut me stuck.
can it be cut with a jig saw (something tile specific) if there is such a thing
or
do you just make consecutive cuts as in image2 (the red vertical lines) till the desired width is achieved then file point 3a to tidy up any rough edge.
or is there a better (easier) way
FYI the cut is to fit round a décor end panel for a kitchen floor
The image dimensions are out but its just a guide to explain the issue
Cheers
James :help:
Has thanked: 735 times
Been thanked: 2340 times
nah to time consuming
2 parralel cuts 4mm short assuming its less than 1" then break the waste
file to the line
if its greater than 2" then finnish with a jigsaw curving over the last 3 inches
then when you cut into the corner you reverse the cut to aim at the other corner then you nibble with the jigsaw or file clean
Duck_Tape
Cantseeitfrommyhouse
Has thanked: 36 times
Been thanked: 108 times
Post by Cantseeitfrommyhouse »
Use diamond wheel or angle grinder with diamond disc etc to cut the 2 x down the tile.
Then carefully score the the tile between the two cuts with a standard rail tile cutter (or tile scriber)
Tonk waste piece firmly onto something solid but not too hard, and theoretically at least you should have minimal ceramic remaining in the middle. I would then normally use the angle grinder to remove any excess ceramic at the bottom of the cut, if there is a slight burr.
These users thanked the author Cantseeitfrommyhouse for the post:
Duck_Tape
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
or, buy a round tile saw.
These users thanked the author thescruff for the post:
Duck_Tape
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
These users thanked the author ultimatehandyman for the post:
Duck_Tape
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Or, cut down the decor end panel and slide tile underneath.
The way I normally do it, has already been given, but thought I would give you another option.
Duck_Tape
Duck_Tape
Post by Duck_Tape »
Thanks All. Thats isexactly what I needed to know
I will go with the info in the vid clip posted by
"http://www.ultimatehandyman.org/video/t ... e-cuts.php"
Cheers
James
Duck_Tape
Post by Duck_Tape »
Ooops
Sorry "Cantseeitfrommyhouse"
you sugested it first so
:thumbright:
:thumbright:
double thumbs up for you
Cheers
James
Duck_Tape
Re: Cutting a strip from a floor tile (ceramic)
Post by Duck_Tape »
Hi to all that helped it worked a treat using this solution
Cantseeitfrommyhouse wrote:Use diamond wheel or angle grinder with diamond disc etc to cut the 2 x down the tile.
Although I used a small tile file for any burrs ratehr than an angle grinder
Cheers
James
:salute:
