Converting into PDF
- Has thanked: 77 times
- Been thanked: 335 times
Converting into PDF
I need to email off a couple of reports in the morning.
I dont want these to be able to be altered easily, Ideally I would send them as PDF files, but how?
I will type them up in word, but how do i change them .wps to .pdf?
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: Converting into PDF
Hitch,
How big are the .wps documents?
If less than 6MB then do it online for free:
http://www.en.conv2pdf.com/
dave
dave
But you cannot tell him much.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
PDFCreator, just drag and drop the docs and save as.
Or if you email them over I can do it and send them back.
-- Fri Apr 30, 2010 9:50 pm --
You guys may be interested in this as well.
http://www.giveawayoftheday.com/simpo-word-to-pdf/
I have downloaded the freebie programme to try when i have typed it all up. If not, ill try that link. Failing that, ill drop you a PM scruff!
Cheers :)
Cheers :)
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Google pdf printer to see what turns up
http://www.cutepdf.com/products/cutepdf/writer.asp
is typical.
I use Broadgun pdf machine which I find to be very reliable
is typical.
Hi all my first post so be kind
Just recently I had exactly the same problem I needed to produce reports and convert them to pdf format.
I tried various tools and online resources and all seemed to work ok but, by far the easiets way was to load the word files into open office and simply use the convert to pdf option on the main toolbar, since then I tend to use open office for all my work rather than Microsoft Office, it is open source and therefore free I have also found that there is a version of open office called oxygen office(available from sourceforge) which has all of the templates and extras that you find in MS Office already built in and is also open source.
here are the links.
Open Office and Oxygen Office
hope this helps
here are the links.
hope this helps
- James Morris
- Has thanked: 4 times
- Been thanked: 9 times
I use OpenOffice as suggested by edjon. I think it is far more flexible than MS (especially 2003) but it can use up a lot of processing space when starting up the computer. I found it better to disable the "auto-load" feature, or better still, go and make a coffee while you are waiting!
Regards,
James
Regards,
James
Hi James,
Yes I have noticed that as well so I don't use the autoloader but I have used it for Spreadsheets, and Database work as well as Word Processing and I really like the product and think it's great that it is opensource I have also found that if you have a problem with it the support community are very helpful
Jon
Jon
There are lots of softwares are available on Internet. You can also purchase it. Some sources are free. You can use PrimoPDF, Allpdfconverter and pdf995 etc. With the help of it, you can easily convert your some types of file into pdf file.
Mistakes are the portals of discovery
