Help with Cutting this type of tiles
- Has thanked: 11 times
Hi to all:
First time posting here and thanks for any help:
I am about to tile a room using the following two models of tiles
http://www.presafor.com/pag_inicio.php? ... 9&pagina=1
http://www.presafor.com/pag_inicio.php? ... ubgrupo=38
Could anyone give me a few tips on how best to cut these, all but two will be straight cuts, the other two are for around a window. I dont have a powered wet saw but have various sized angle grinders and can get whatever blades may be required. Getting hold a powered wet saw is not easy and for the amount of cutting a little expensive.
Many thanks for your time and help.
Nias
Nias
- Has thanked: 4 times
- Been thanked: 49 times
Re: Help with Cutting this type of tiles
are they ceramic if so theyl cut with a diamond tipped blade dry or wet!
IF IT WERE EASY ITD B BORING!
- Been thanked: 19 times
My Spanish isnt up to much so dont know what material they are made from although at 20mm thick they are almost certainly some type of stone. If you're using an angle grinder, check out the Marcrist CK850 diamond blade. Try clamping them to a bench with some timber to keep them still whilst cutting and dont forget your PPE.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
I think it's a sort of stone/cement mix.
A diamond blade will eat it anyway.
Thanks for your help:
The material is some sost of pressed/formed material with what looks like chips of marble. And the "Moldura A" for around the windows /doors have three rods of steel through them.
Rookery:::: Thanks for the reminder, have my goggles etc ( easy to forget when you are busy)
Have to say this forum is excellent and will no doubt use many times. Cant be much help on the diy/handyman front but can offer most things on the computer side.
Thanks again and will check back later.
By the way its raining and cold here in "SUNNY SPAIN"
- thescruff
To Scruff
Not far from a city called Alcoy. In the country with the worlds slowest internet conection -- hence my delay in reply.
Apart from the services here I love the place.
Nias
Nias
- thescruff
Pais Valenciano, blimey I'm surprised you have electric that far inland.
- thescruff
Just a quick thanks to all who helped me on this. Brought a decent diamond blade for my disc cutter and it worked well. Just a bugger to grout
Thanks again
Thanks again
