Help with Cutting this type of tiles
nias43
Has thanked: 11 times
Post by nias43 »
Hi to all:
First time posting here and thanks for any help:
I am about to tile a room using the following two models of tiles
http://www.presafor.com/pag_inicio.php? ... 9&pagina=1
http://www.presafor.com/pag_inicio.php? ... ubgrupo=38
Could anyone give me a few tips on how best to cut these, all but two will be straight cuts, the other two are for around a window. I dont have a powered wet saw but have various sized angle grinders and can get whatever blades may be required. Getting hold a powered wet saw is not easy and for the amount of cutting a little expensive.
Many thanks for your time and help.
Nias
marc1106
Has thanked: 4 times
Been thanked: 49 times
Re: Help with Cutting this type of tiles
Post by marc1106 »
are they ceramic if so theyl cut with a diamond tipped blade dry or wet!
These users thanked the author marc1106 for the post:
nias43
IF IT WERE EASY ITD B BORING!
Rookery
Been thanked: 19 times
Post by Rookery »
My Spanish isnt up to much so dont know what material they are made from although at 20mm thick they are almost certainly some type of stone. If you're using an angle grinder, check out the Marcrist CK850 diamond blade. Try clamping them to a bench with some timber to keep them still whilst cutting and dont forget your PPE.
These users thanked the author Rookery for the post:
nias43
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
I think it's a sort of stone/cement mix.
A diamond blade will eat it anyway.
These users thanked the author thescruff for the post:
nias43
nias43
Post by nias43 »
Thanks for your help:
The material is some sost of pressed/formed material with what looks like chips of marble. And the "Moldura A" for around the windows /doors have three rods of steel through them.
Rookery:::: Thanks for the reminder, have my goggles etc ( easy to forget when you are busy)
Have to say this forum is excellent and will no doubt use many times. Cant be much help on the diy/handyman front but can offer most things on the computer side.
Thanks again and will check back later.
By the way its raining and cold here in "SUNNY SPAIN"
thescruff
Post by thescruff »
Where about's in Spain are you.
nias43
Post by nias43 »
To Scruff
Not far from a city called Alcoy. In the country with the worlds slowest internet conection -- hence my delay in reply.
Apart from the services here I love the place.
Nias
thescruff
Post by thescruff »
Pais Valenciano, blimey I'm surprised you have electric that far inland.
nias43
Post by nias43 »
LOL :lol:
Electric and water "SOMETIMES"
But the people here make up for it.
Buenas Noches y hablar pronto
Nias
thescruff
Post by thescruff »
Sleep tight. :thumbright:
nias43
Post by nias43 »
Just a quick thanks to all who helped me on this. Brought a decent diamond blade for my disc cutter and it worked well. Just a bugger to grout ::b
Thanks again
