Need some ideas guys.
I have a circular window (575mm Dia) in my en-suite, which I am tiling using narrow slices of the main wall tile.
What can I use as a tile-edging, to mask where the veritical wall tiles and the slices of tiles I am using in the circular window reveal, meet?
Are there any tile trims that you can bend around into a circle to mask this joint.
Thanks in anticipation.
R
Jim.
Tile Trim for a Circular Opening?
- Has thanked: 1 time
- Has thanked: 39 times
- Been thanked: 621 times
Re: Tile Trim for a Circular Opening?
Various options..................
Schluter do a trim which can be bent.
Plastic trim, cut and heated to form a curve.
45 degree edge cuts to tiles (making your own jolly tiles in other words)
Thanks Royal Oak,
Going for the Shluter.
R
Jim
R
Jim
- Has thanked: 5 times
- Been thanked: 23 times
cut ..V..sections out the back of your trim,(all the way round).then gently bend to suit.. onto a bed of addy and use pins/screws to hold in place till the addy sets.
