- It is currently Thu Apr 17, 2025 11:40 pm
Wheel change
- Has thanked: 1 time
Wheel change
Sorry for dumb question. I need to change a rear wheel on my peugeot 406 lx dt diesel next to the fuel tank. I know the steps for changing a wheel but I haven't done it before. I have borrowed a jack from someone's Audi - is that ok? The jack I am using has a gap or slot to take a ridge and also a flat bit (see pic here).
Are these two alternative points of contact or is only the slot the point of contact? There is a ridge on the Peugeot which I can use = the long strip of painted metal panel running below front and rear doors, which I think is welded to other parts of the body above and to the left. So is the correct place for the jack? Of course if it is not able to take the weight it will break off. I have looked around but I can't see any other alternative ridge to use. There is a flat bit of metal further which I think is part of the chassis but it is about six inches wide ie not a ridge.
Any help please??
-- Thu May 27, 2010 10:49 pm --
car ridge pics...
Any help please??
car ridge pics...
Juc1
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: Wheel change
Not the right jack for the job.Juc1 wrote:Sorry for dumb question. I need to change a rear wheel on my peugeot 406 lx dt diesel next to the fuel tank. I know the steps for changing a wheel but I haven't done it before. I have borrowed a jack from someone's Audi - is that ok?
The 406 uses a scissor jack like Dead link removed by admin
Using the one in the your picture will probably do some serious damage to the sill or even collapse.
Either borrow the correct type for thew sills or get a bottle jack from someone and get it positioned under the axle.
dave
But you cannot tell him much.
dave.m
Re: Wheel change
OK thank you, l didn't know that some jacks can only be used on particular cars.dave.m wrote:
The 406 uses a scissor jack like this one
dave
- scissor.jpg (91.17 KiB) Viewed 2759 times
Juc1
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Re: Wheel change
The problem with bottle jacks is getting the car high enough off the ground to get it under, especially if you have a puncher.
Best to buy a small trolley jack.
thescruff
- dave.m
Re: Wheel change
Check out your local peugeot dealer or Halfords.
You should get the scissor jack if possible so that it will fit in the wheel well in the boot.
I trust you have looked there for the original jack.
dave
dave
dave.m
- thescruff
thescruff
- dave.m
Re: Wheel change
When I was Cabbying, the 406 had it under the rug in the wheel well in the boot. Some vans have them under the bonnet but don't know which ones.thescruff wrote:Don't they keep them under the bonnet anymore Dave.![]()
dave
dave.m
Re: Wheel change
Yes I got the original scissor jack (pic above) from the boot but the handle is missing. By the way is there a name for the Audi jack ie the unsuitable one?dave.m wrote:
dave
Juc1
- thescruff
thescruff
- dave.m
Re: Wheel change
Yes, it is called a 'side jack' and is specifically shaped for one particular car. Using or trying to, on a different car can be very dangerous.Juc1 wrote:By the way is there a name for the Audi jack ie the unsuitable one?
dave
dave.m
Re: Wheel change
OK thanks, the scissor jack in my pic above is leaning to one side - does that look ok / normal?thescruff wrote:You'd get a handle from a car scrappy yard, for a quid or so.
-- Fri May 28, 2010 2:28 pm --
Holy moly, thank youdave.m wrote:Yes, it is called a 'side jack' and is specifically shaped for one particular car. Using or trying to, on a different car can be very dangerous.Juc1 wrote:By the way is there a name for the Audi jack ie the unsuitable one?
dave
Juc1
- dave.m
Re: Wheel change
Not really very good.
When it gets the weight of the car on it, it could quite easily fold over or crumple.
Get your self a new jack and handle from Halfords or car accessory shop.
dave
Other alternative is to join the AA and call them them out.
dave
dave.m
- thescruff
Re: Wheel change
The jack in the pic looks like the normal one I had with the 205. They must be used on firm ground though.
If safety is a worry/issue a trolley jack is the best, and safest. And they're not that expensive in Halfords and the likes'
thescruff
- Has thanked: 77 times
- Been thanked: 335 times
Re: Wheel change
Many jacks are maker specific as mentioned.
The one in your pic from your car is fine. The base pivots very slightly to allow it to sit flat on a slope if you need it to in an emergency.
The pivots are probably stiff if you dont use it, take hold and hit it on the floor a few times.
A scrapyard will have shed loads of them handles kincking about i expect...anything citroen or peugeot from the last 15 years probably. Same on my van, same on the wifes.
Hitch
