Help - need a nice lookng cheap tile/bordr for bathroom ?
- Has thanked: 75 times
- Been thanked: 3 times
Hi All
Not sure where to post it and been looking through thr galleries etc.
I am in the process of redoing my bathroom on a tight budget and looking to tile it with a border. Problem is it is quite large and all tiles seem quite expensive.....
Love the look of travertine or something light in colour/sandy..
Anyone in the trade use a smart cheap looking tile or part tiled room to effect ??
Cheers
Cheers
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
Re: Help - need a nice lookng cheap tile/bordr for bathroom
Yes, border tiles are expensive, but they make such a difference. Take a tip from me,
make sure you get enough and then add at least 10%, so you don't end up with a gap behind the mirror as happened to me! Still looking for two that only Tiles r Us sold, then they went bust.
My shame here:
http://www.tileforums.com/index.php?sho ... entry78934
My shame here:
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- Mooncat
Yes, that was the first place I tried, as soon as I knew I was short of two. But there were none in any of their warehouses two years ago. I also needed extra tiles for above the border, and found that Everett Tiles in Sussex still had some, but they had never had the borders.thescruff wrote:Have you asked Azteca direct mooncat
http://www.europages.co.uk/AZTECA-CERAM ... ct-us.html
- Has thanked: 735 times
- Been thanked: 2340 times
if your on a tight budget have you thought about self adhesive stickers
http://homeshopping.24studio.co.uk/kt-s ... 0Transfers
various sorts to choose from
- Been thanked: 19 times
There are plenty of cheap ceramic travertine look-alikes around. e.g. Padova 80 is one of Topps best sellers. Make a border to go with them from travertine mosaics.
Rookery wrote:There are plenty of cheap ceramic travertine look-alikes around. e.g. Padova 80 is one of Topps best sellers. Make a border to go with them from travertine mosaics.
Anyone used these tiles ?
Do you use them from floor to ceiling on walls ? and on the floor or does it look to much ??
Not good at picking these sort of things and got no woman handy to do it for me...lol
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
I'm not a lover of all walls floor to ceiling, we did 2 walls the ones the bath is in contact with and we have an over bath shower. The other walls are just painted plaster.
Quite light and less imposing than all 4 walls tiled. The room is also quite small.
Would be a budget saver only doing 2 walls too?
Jaeger.
- Has thanked: 4 times
- Been thanked: 49 times
as yeager says just tile the areas that need it then paint the rest, it saves money and makes a change cheaper too as a gallon of emulsion is nowhere near as expensive as a room full of tile, if your not full tiling why not get a nice metal trim to finish the tiles with less expensive option again!
IF IT WERE EASY ITD B BORING!
- Has thanked: 39 times
- Been thanked: 621 times
I am with Jaeger and marc.........Whether it is a mahoosive bathroom with bath, separate shower and bum washer or a tiny bathroom where you hit your head on the wall drying your feet, fully tiled looks pants.
Just something about having areas of painted walls which breaks the room up, adds interest and makes it less sterile looking.
Thats the single box price. If you buy 4 sq mtrs+ they are £20.93 for the 316 x 316 or £27.93 for the 316 x 450.bilabonic wrote:EDIT - Just checked Topps sit, the cheapest is 35 sq/m !!!!!!!!
I've used them several times.
wickes and B&Q do travertine effect ceramics, not sure of the prizes or sizes though, but probably cheaper that 20odd a meter, (just dont buy cheap addy).
- Has thanked: 3 times
- Been thanked: 4 times
If you want a simple boarder, then just buy a pack of sheet mosaics, normally about 12" x 12" square and then just cut them into strips.
Have done this plenty of times.
These are the sort of things -
They are only £20 for a pack and you will probably do the whole room with some to spare (unless its a massive room ...
