Polishing Travertine tiles
arthurx1234
Post by arthurx1234 »
We had someone fill in the cracks in 3 Travertine tiles, he used some sort of filler and then buffed the 3 tiles up and they are now very shiny.
The other half would like the whole floor polished.
Can i use my drill with a backing plate and one of those wool polishing mitts or would i have to use something more abrasive (which i am not too keen on doing)
Also the guy left behind a bottle of CTF-40 BY FEDERCHEMICALS,most of the writing is foreign however the only words in Eglish are "protective water oil repellent" any idea how i use this?
cheers
builderbanter
Re: Polishing Travertine tiles
Post by builderbanter »
I think what you have there is an impregnator, or a sealant/glaze product. These can be used, but it's always best to check the manufacturers instructions, which you can't do!
I think your best bet would be to try it on a spare tile (if you have one) or on a hidden/less obvious tile.
Hope this helps.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
CFT40 is an Anti-stain for marble and Granite tops and surfaces.
leebwk
Has thanked: 3 times
Been thanked: 31 times
Post by leebwk »
to be honest i would get someone in to strip the floor and then re-polish because believe me it is not a simple process and i have had the same problem, all in all it takes about half a day to strip, polish and re-seal, cost me about £200 in all which was well worth it, because materials used came to quite a bit
