Excell
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: Excell
"window" - "arrange"
- thescruff
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- kellys_eye
Re: Excell
You could always use the TABS at the bottom instead of two separate forms (copy/paste into new form afterwards if you're that bothered).
Also, with tabs, you can make cell references between pages easily.
-- Tue Jul 27, 2010 1:34 pm --
Open your first spreadsheet.
At the top right of the screen UNDER the usual screen 'restore down' sizing icon, click on the other 'restore down' button.
Now grab the bottom corner of the sheet and size the form to whatever you require.
Open another 'new' spreadsheet and repeat. Drag to place them side-by-side.
- thescruff
Re: Excell
I was doing that the first time Kelly_eye, but when you open the second it replaces the first.
I can do what I want using the arrange button thanks.
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Re: Excell
The other option is Windows - arrange side by side?
Nick
- thescruff
Re: Excell
Thats what Kellys_eye saidnick200 wrote:The other option is Windows - arrange side by side?
- nick200
Re: Excell
I know but my computer has two buttons
The first is 'arrange' where I can do Tiled, Horizontal, vertical and cascade
The second is simply arrange side by side which I find helpful if I want the two to scroll....
Plus also probably because I did not read the message properly!!
Nick
- thescruff
Re: Excell
Do you know how to set up Virgin on a Mac, because it's peeing me off at the moment.
It used to work, but they've change it to ssl
- RichieP
- UHM Super Moderator
- Has thanked: 4 times
- Been thanked: 12 times
Re: Excell
They're gradually moving everyone over to this, without actually telling most people. I don't mind, as people are calling me to help them when can no longer access their email
It's the same as Googlemail basically. This should help.
- thescruff
Re: Excell
Thanks Richie.RichieP wrote:They're gradually moving everyone over to this, without actually telling most people. I don't mind, as people are calling me to help them when can no longer access their email
I figured the windows out but the mac didn't want too know.
However, now I know how to spell blueyonder, all is working on the mac as well
