retiling over old tile adhesive
giggles
Has thanked: 2 times
Been thanked: 3 times
Post by giggles »
i have removed the old tiles and want to put up new tiles
do i have to scrape off whats left of old adhesive or can i tile over it?
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: retiling over old tile adhesive
Post by royaloakcarpentry »
What is behind the adhesive??? Plaster or plaster board?
giggles
Post by giggles »
plaster
royaloakcarpentry
Bucket of hot water and a brush. Brush water onto adhesive and leave for 20 minutes or so. This will soften the adhesive and then you will be able to scrape it off with a decent scraper. You may need to brush on a couple of times.
If you haven't got one, buy a long handled scraper that takes what looks like an over sized Stanley blade. Once adhesive has softened enough it will scrape off like butter, only not yellow.
Rookery
Been thanked: 19 times
Post by Rookery »
That will work if its dispersion adhesive (ready mixed) but not if its cement based. A good scraper and plenty of elbow grease is what you need.
royaloakcarpentry
My money was on tubbed addy being on the walls.................might just be luck, but I have never taken tiles off the wall to reveal cement based addy.
giggles
Post by giggles »
well the sister went and tiled over the old adhesive :cussing: :cussing: :cussing:
so its like a moto cross track! grouted and all :roll:
so theres a 11mm gap between bottom line of tile and worktop one end
and 2mm the other end!... so goin to silicone the gap as i'm told that grout would just crack
with movment in a wooden worktop
so the question is which silicone?
royaloakcarpentry
dow corning
Rookery
Post by Rookery »
I would have thought the differing gap is due to the worktop or tiling or both being out of level. The gap at the junction of worktop and tiles should always be siliconed as its a movement joint. Even if the worktop is granite. If white, I use Dow Corning 785 sanitary silicone, Mapei if I want a coloured one.
giggles
Post by giggles »
differing thickness in the pieces of cardboard to protect the worktop while tiling/grouting :roll:
the cheek a ya... the wortop is level :wink:
MASSEY
Been thanked: 2 times
Post by MASSEY »
scrape it off. Tiling is hard enough as it is, try make the task as painless as you can.
Beachcomber
Has thanked: 28 times
Been thanked: 71 times
Post by Beachcomber »
With a difference in tile / worktop join like that I'd cover it with a length of upvc quadrant / beading.
And 11mm silicone bead will not look good for long - even if you use Dow Corning.
Nice bit of quad will hide the gap nicely.
