new worktop
- Has thanked: 3 times
- Been thanked: 31 times
Hi juandan,
You can do it either way really obviously fitting the sink to the worktop first is easier for access to the sink and tap fittings, i would lay the worktop in position first cut to the right length then mark out sink position, remove and cut in new sink with fittings then refit.
Hope this helps
Hope this helps
