Makita 10.8v twin pack impact driver and drill
Re: Makita 10.8v twin pack impact driver and drill
It all depends on what size screws u are using it will drive 32mm dry line screws in for a couple of of hours, I've been using impact driver for drylining and is excerlent you can easily control how far the screw head gos in I also u a dryline bit that stops the screw head going in to far it has a stopper on it, don't know u have come across them your self but if not.... invest it will be the best coulpe of pound u spend!!
Thanks dan.
Thanks dan.
- Has thanked: 734 times
- Been thanked: 2333 times
I have the complete set excluding tin snipsmightymart wrote:I did have the pleasure of using these drills to do a bit of drylinning & really liked them especially the impact driver, but was wondering how the impact driver would fair (battery life) doing a full days work on site of plaster-boarding ?.
At the moment Im toying between buying this set because of the lightness or just buying a bare body 18v lithium impact driver seeing i already have a drill driver & batteries etc
I was actually disappointed with the impact it performed no better than the origional drill driver or the older 2 speed drill driver and they all perform the same where as you expect the impact to kick 2 or 3 times its weight
It's on 10.8 v 1.3ah u can't ask for much, that's y I have the bigger makita 18v lion 3ah twin set, the smaller ones are only fir light work dose wonders when fitting kitchens!! Also just got the makita nail gun, pisses on paslode. Also worth buying!
Thanks dan.
Thanks dan.
yes i understand the 10.8 kicks well above its weight in fact when i am fitting bespoked furniture i have built i only take the 10.8 unless i have to drill a hole in masonary because all the kit is in the same small boxsmify06 wrote:It's on 10.8 v 1.3ah u can't ask for much, that's y I have the bigger makita 18v lion 3ah twin set, the smaller ones are only fir light work dose wonders when fitting kitchens!! Also just got the makita nail gun, pisses on paslode. Also worth buying!
Thanks dan.
i have the bosch 14.4v and the ryobi 18v impact driver
the battery size is irrelevent as is the voltage the impact should kick aaarrssee it should propel much larger screws into the wood compared to the hammer drill or drill driver off the same kit
- mightymart
Thanks Guys just the answer I was looking for before I went ahead.
I ordered the bare body Makita BTD 140 £85 inc postage from ebay instead, so really I have saved a few quid as I would have had to purchase a holster to ! & the BTD is the same rpm as my old Dewalt cordless drywall gun .
I really like these little drills & they seem to be more than ample but I thought the batteries might not be up for a full day without changing & charging batteries like the old days (Horses for courses) , plus I have both a 240v & 110v 18min charger for the 18v lions so I always have power.
smify06 : This is the drywall bit holder I use, Dont know why the the bit isnt actually in the packet (old picture, & I dont even know why I have it !)
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Is that from George Higgins at Station road in Sidcup??
Spent hours in there over the years when I lived down that way
- mightymart
Yes, spent hours & loads of money in there too !!!Razor wrote:Is that from George Higgins at Station road in Sidcup??
its like an automatic gearbox that selects a lower gear as the load gets to much it changer gear for more power iff you stop it changing gear it will just stallquantum wrote:Just wondering - Can you turn off the impact bit of the driver, to use on slightly less arduous jobs?
John
so iff you isolated the impact function you would have no more than a small driver
