Seat leon "overheated"
81ash
Has thanked: 1 time
Been thanked: 8 times
Re: Seat leon "overheated"
Post by 81ash »
The garage sound useless, whilst it might be difficult for a DIYer to categorically test, a garage should have the equipment on hand to test it much better.
As for Radweld, its normally safe for nearly all engines (even rover engines - unless you have the KV6 engine 2.7, which it was'nt suitable for due to the narrow waterways). That said your usually better to try a long term fix for the problem, i recently had a tiny weep from my around around the fan switch, rather than drain the whole system to replace it i used a bit of radweld in the system which cured it.
the_grafter
Been thanked: 2 times
Post by the_grafter »
sounds like air blockage mate drain all the water system down refill etc and then check again
