Best silicone for around the bath?
We had our bathroom done about 18 months ago, in a couple of places a very small bit of the silicone has split. We went over it with more silicone as a temporary measure so it didn’t do any damage to the room below when we use the shower but it really needs to be removed and redone. Which is the best white silicone to use for around the bath?
Thank you very much everyone for all your advice.
Re: Best silicone for around the bath?
Thanks tictac. There's so many to chose from.
- Has thanked: 8 times
- Been thanked: 17 times
- Contact:
Thanks also from me, I was about to ask the same thing!
ATB,J.
ATB,J.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
tictic wrote:dow corning 785.
For white silicone most professionals use nothing else
- Contact:
Well if it's good enough for the pros, then I guess it'll just about do for us plebs!!
ATB,J.
- Has thanked: 28 times
- Been thanked: 71 times
Another vote for 785 - best I've used.tictic wrote:dow corning 785.
http://www.screwfix.com/prods/38292/Sea ... lear-310ml
Beachcomber wrote:Another vote for 785 - best I've used.tictic wrote:dow corning 785.
Thanks for the link Beachcomber.
