- It is currently Tue Apr 22, 2025 7:57 pm
Building an aquarium question.
- Has thanked: 2 times
Hi all, i am in the planning for building an aquarium, now at the minute i am going with plywood and fibreglass. But there is always the choice of steel, the thing i am stuck on is what to seal the steel with on the inside, i would want it to last for many years and obviousley be fish safe.
So the Q is what could i seal the inside of the aqurium with, or even all of it in and out.
Thanks wayne
Thanks wayne
W.olly
- Has thanked: 740 times
- Been thanked: 2356 times
Re: Building an aquarium question.
no sense off scale here
aquarium is that not a selection off tanks and pools???
- Has thanked: 77 times
- Been thanked: 335 times
How would you see your fish.....
Or do you mean a tank stand?
Hitch
Well for the scale it is going to be around 1200 gallon, 9 x 7 x 3 foot.
There will be a viewing window in one side ,looking into the tank/aquarium from the conservatory.
I am either going to build from plywood/grp, conrete of either block or poured, or as here steel, just depends on build cost of all, i think steel would be expensive but worth looking into.
Glass is way out of my budget at around £5000 so thats a no no.
I can do all the fab work myself as allthe build work otherwisesoitalldown tomaterials.
My main concern is what to seal the inside of a steel tank with?
wayne
wayne
W.olly
you have i believe 5.3cu.m. or 4 tons assuming 27% air space at the top
you will need a hefty structure off possibly 2 or 3 tons including tank
If you need a sealed steel tank, just fully weld all joints on the inside....youd probably be looking at fairly decent plate thicknesses with some bracing.
Id be more concerned with the water issues.... unless you went down the stainless route...
Hitch
Thanks for the replys but the Q was
W.olly
Im lost, i could probably help, but dont understand what you are trying to do. If you make a steel tank you would seal the corners with weld.
Hitch
An aquarium needs to be sealed from chemicals etc, all the nastys that will kill fish, like with concrete ponds, they needs to be sealed, with a pond sealer of some sort. G4 GRP etc
A mild steel tank would corrode ( stainless is to expensive ) not good on the fish i am keeping. It is for fresh water fish, not salt water.
Now i will be or would be welding al the seams etc, brace bars etc, but i need to find a good way to seal the tank from the water on the inside and maybe the out side.
I am not sure on the wall thickness as yet but i have decided to use U channel instead of box section as to save from rusting on the inside, this will be used alround for the brace/bearers and viewing window frame.
W.olly
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Post by kellys_eye »
What kind of 'poisons' do you expect to leech from plain old steel immersed in water? Personally I wouldn't bother.
kellys_eye
mmmm ship wrecks make good reefs
they sink ships and even old railway coaches from the new your subway to act as reefs
http://www.reuters.com/article/idUSN1643767620080517
- Deceased 21-10-2011 R.I.P
- Has thanked: 8 times
- Been thanked: 90 times
Powder coating?
Stoday
- kellys_eye
Stoday wrote:Powder coating?
doesn't that require a 'baking' process? Can't imagine getting that tank in an oven.....
kellys_eye
Well then, after looking into all the ways to do this, concrete block, poured concrete, all wood and resin seal plus more, i am going to go with a steel fame of maybe 3x2x1/4 U channel and a bit of 4x2 channel with a ply line and grp seal.....although it can change
you see concrete block is cheaper but thern theres the concrete for the tank base, not the fish room base oooooo decisions, we will see i will be starting this in the new year once i have drawn up the plans and the slab base.
W.olly
You take it to a commercial powder coater. Geez, if I said "hot dip galvanised" would you say you couldn't get it in a pot?kellys_eye wrote:Stoday wrote:Powder coating?
Stoday
