cutting square hole
- Has thanked: 39 times
- Been thanked: 621 times
Re: cutting square hole
4.5 inch angle grinder, shut the door and open the window.
Wet cutter
Special scoring bit for manual tile cutter which will gradually gouge out the back of the tile, depending on what sort of tile it is. Very time consuming.
Wet cutter
- dunaird
- Has thanked: 735 times
- Been thanked: 2340 times
if your not used to using an angle grinder
drill 3 or 4 8mm holes in each corner and cut to a strait edge held on with sticky tape
make sure the cut out is 2-3mm bigger than the back box
The Bosch PMF 180E will cut a square out of a tile as long as you use the tile cutting blade, but it won't be as easy as the angle grinder method.
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
I have done what UHM suggested with the grit blade on the PMF but its very slow, You get there in the end
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
I disagree, close the window, open the door, go outsideroyaloakcarpentry wrote:4.5 inch angle grinder, shut the door and open the window.
but yeah, angle grinder, rotozip, plunge cut
what type of tile by the way?
- bodgitandscarper
Wet cutter, remove the guard, glazed side up, plunge cut, quite easy, have a practice on a couple of old tiles, you'll soon get the hang of it..........
- These users thanked the author bodgitandscarper for the post:
- dunaird
