Hanging kitchen wall cabinet from stud partition
i8diy
Has thanked: 1 time
Post by i8diy »
I'm fitting a corner wall cabinet in the kitchen and have encountered a stud partition directly in line with the position i had planned to fit the hollow wall anchor.
Is there any particular screw i could fit directly into the partition? I've looked at self-tapping screws but haven't found anything longer than about 50mm at the main DIY places. Would this be sufficient? Or is there anything better, like a coach screw, etc?
speed
Has thanked: 35 times
Been thanked: 257 times
Re: Hanging kitchen wall cabinet from stud partition
Post by speed »
you mean thers is a timber where you need to fix? just screw a woodscrew in, a 2" 10 screw ( 5 x 50mm in metric)
Simon Site Manager
Has thanked: 48 times
Been thanked: 202 times
Post by Simon Site Manager »
Hi i8diy,
A 75mm (3inch) 10 would be safe. Obviously fixing into a stud is preferable to plasterboard fixings!
S
Measure twice, cut once!
Has thanked: 736 times
Been thanked: 2341 times
are you talking wood or metal stud work
how thick is the full wall hopefully around 115mm
nowt happens then three come along at once :lol: :lol:
i8diy
Has thanked: 1 time
Post by i8diy »
The stud is wooden. A wood screw with a countersunk head won't work because the cabinet will simply slip off the fitting.
I really need a round headed screw like a self tapping screw but i can't find any that are longer than about 50mm. Will this be long enough to hold the weight of one corner of a wall cabinet if there is a hollow wall anchor supporting the other corner? Or would it be better to use something more substantial like a coach screw?
i8diy
Has thanked: 1 time
Post by i8diy »
speed wrote:you mean thers is a timber where you need to fix? just screw a woodscrew in, a 2" 10 screw ( 5 x 50mm in metric)
Will a 5 x 50mm wood screw be strong enough? Plasterboard is about 12mm thick, stud partition is directly behind. Allowing for about 8mm sticking out to hang the corner of the cabinet on, that only leaves about 30mm of screw in the partition. Will that be secure?
100% off fittings for kitchen cabinets will be designed to be used with wood screws or to hang on fittings secured by wood screws
have you got a picture
ok you need to cut out and use spacers as you are describing dot and dab
i8diy
Has thanked: 1 time
Post by i8diy »
big-all wrote:ok you need to cut out and use spacers as you are describing dot and dab
It's NOT 'dot and dab'. Will you please stop confusing the issue!
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
I'm a bit confused by these cabinet fittings. All the one's I've fitted worked fine with normal csk woodscrews.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Perhaps if you explain what you are trying to do better, the experts wouldn't be confused. ::b
For a starters, a wood screw into an wooden upright with be 10 x stronger than a cavity fixing. :roll:
Simon Site Manager
i8diy,
Being rude isn't going to get you any help!
S
northwales4u
Has thanked: 76 times
Been thanked: 151 times
Contact:
Post by northwales4u »
These users thanked the author northwales4u for the post:
i8diy
Mike
i8diy
Has thanked: 1 time
Post by i8diy »
thescruff wrote:Perhaps if you explain what you are trying to do better, the experts wouldn't be confused. ::b
You mean the sort of 'expert' who doesn't know the difference between 'dot and dab' and plasterboard that's fixed to a STUD PARTITION?! I only mentioned it three times, perhaps that wasn't enough.
Locked
Return to “Kitchen Fitting”
