masking around bath for sealant..
stingray316
Post by stingray316 »
l'm putting sealant around the bath and would like to know if anyone can tell me the best tape to use as l want to make a neat sealant finish... l've tried masking tape on the tiles and bath and it will not stick very good and starts peeling away before l can put the sealant on.. Are there any tapes intended for this job, or any that will stick ..
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Re: masking around bath for sealant..
Post by DIY_Johnny »
You don’t need tape; there are various sealant applicator tools that make a very neat job, much better than a nasty wet finger. There is one call fungenboy on screw fix that is very good. It will put a neat edge and scrape off any access from the tiles. It takes a little bit of trial and error to get the amount of sealant right; otherwise you end up with a big blob on end of the tool. You also have to angle it so you don’t necessarily follow the grout line. But when you do you get a very nice finish
I have seen others in B&Q that look fine also.
I always think its a shame when you get a nice bathroom installed you let it down at the last minute with a nasty sealant line
Just checked, the Fungenboy seems to be gone now from screwfix but available on the web
fred99
Has thanked: 9 times
Been thanked: 6 times
Post by fred99 »
Yep, fugenboy is the way to go, or there are alternatives on fleabay
I have this set aswell,
http://cgi.ebay.co.uk/Silicone-Applicat ... 3a61250647
DIY_Johnny
Mr. Grumpy
I just wish they would make those fugenboys coloured as I am constantly losing mine and its like a scene out of CSI till we all find it
fred99
Post by fred99 »
DIY_Johnny wrote:I just wish they would make those fugenboys coloured as I am constantly losing mine and its like a scene out of CSI till we all find it
I know what ya mean :lol:
They also do one of these tools in Wilko's for about £6 and its yellow.
zedhead
Has thanked: 64 times
Been thanked: 19 times
Post by zedhead »
stingray316 wrote:l'm putting sealant around the bath and would like to know if anyone can tell me the best tape to use as l want to make a neat sealant finish... l've tried masking tape on the tiles and bath and it will not stick very good and starts peeling away before l can put the sealant on.. Are there any tapes intended for this job, or any that will stick ..
I have always used masking tape, clean then buff both surfaces making sure they are dry and not too cold, some grades of tape are better but even the cheapest works ok. Take your time with the masking, apply silicone, wipe with your pinkie then remove the tape asap.
Baza
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Running joints in with a finger might be ok for a novice working on their own house but totally unacceptable when it is being charged for.
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
Using an old credit card, you can cut one of the corners to any shape you would like the profile to be.
Always tilt it forward in the direction you are scraping, that way it will glide over the recess between each tile without dipping into the gap where the grout is.
dave
But you cannot tell him much.
royaloakcarpentry
Many ways to do it. As already advised, Fungi tools, credit card...............make a stick from timber, a whittled ice lolly stick, plasplugs do a set of tools. A decent sealant gun and also quality sealant makes a huge difference. Instead of applying the sealant by pulling the gun away from the start point as you apply the sealant, have your start point and push the gun so that you are smoothing as you apply.
zedhead
Post by zedhead »
I think OP was asking from a diy point of view.
Baza
Chris the builder
Has thanked: 10 times
Been thanked: 22 times
Post by Chris the builder »
I always mask windows & bathrooms, but if masking tape won't stick to your tiles, make sure they are fully degreased/de-scummed lol, as if the tape won’t stick, it’s a good indicator that the tiles aren't "clean"so the silicone wont either.
P.S
I was told years ago, to mask up, rub the bath gently with wire wool, clean off & remask.
Chris the builder
fred99 wrote:Yep, fugenboy is the way to go, or there are alternatives on fleabay
Hmmmm........ never used one of these before, so just bought one to test out.
Cheers.
Chris the builder
Cheers.
Lol just watched the video too, looks exellent!
royaloakcarpentry
I use those and they are a most excellent addition to a tool box. I used to use small offcuts of timber formed to shape but rarely use that method now.
DIY_Johnny
Mr. Grumpy
looks like more functionality that the fugenboy ones
