Intergas 24/18 HRE compact Combi
- Mehran2
- Has thanked: 6 times
- Been thanked: 39 times
Re: Intergas 24/18 HRE compact Combi
sounds good,
Is the flue the 'rhino' type with the up turned nose? and did you get kit A in the end?
a good idea at this stage is to see if the little PRV stub and nut can be unscrew. I have found some that are rock hard to unscrew and almost have to take the boiler off the wall to unscrew them. I think they pre-wet the washer or something? by the time it gets to you it has dried and stuck solid.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- thescruff
Here we go then.
Draining the system and cylinder out 8:00.
Got till 4:00 to get the new boiler in and working,
Intergas, be warned it had better work
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Silly biatch forgot to post it!!! But it went Saturday Scruff
Theres nothing stopping you fitting Plumbcenters one and taking the other one back when it arrives is there?
- thescruff
Old stuffs out, new boiler on the wall and the flow and return connected.
- Razor
thescruff wrote:Old stuffs out, new boiler on the wall and the flow and return connected.
Managed to connect up to the old lead then
- thescruff
No Sweat,Razor wrote:thescruff wrote:Old stuffs out, new boiler on the wall and the flow and return connected.
Hots connected, just the mains and gas to go.
Who forgot the filler loop then
- Has thanked: 29 times
- Been thanked: 149 times
- Mehran2
so good so far I hope
what I like to do is put a full bore valve as a drain on both the flow and return under the boiler. so you fill from one side and drain through the other then swap.
- thescruff
Water comes out the taps.
- thescruffs boiler.jpg (179.11 KiB) Viewed 4064 times
- Razor
Didn't they send all the bits for inside the boiler?
Guess you're adding all the pipeclips aftewards
- Mehran2
looking good
remember it only a 9l/m boiler so make sure the flow rate is not too high
- thescruff
just hit a problem
Have a mini flood in the office at the moment, you didn't tell me I had to cap the cold feed and vent.
- Mehran2
btw I forgot to say to watch for loose nuts inside the boiler. what sometimes can happen is when you tighten the valve under the boiler it can loosen the one above inside the boiler.
if you do get any water in the boiler, intergas have kindly proved a sump under the boiler on the right hand side under the pump. there is a little plastic cap to drain any water away.
not to worry john, we all have forgetful moments
- Razor
thescruff wrote:just hit a problem
That's the funniest thing I've heard for ages
But only 'cos I've done it myself
It's not to late to get BG in you know
And it's a senior moment Mehran
