1m long tiles
vanduara37
Has thanked: 17 times
Been thanked: 3 times
1m long tiles
Post by vanduara37 »
Helping fit a bathroom suite and the the customer was asking if i could do the tiling,when she showed me the tiles they are about 900mm to a 1000mm long,i have a Rubi ts60 proplus but only cuts tiles up to 650mm long,my question is there a cutter that can cut these tiles manually or do the need cut with electric cutter ? (or should i just say can,t do it and save myself a lot of grief :roll: )
Razor
Has thanked: 483 times
Been thanked: 1251 times
Re: 1m long tiles
Post by Razor »
I'd usually use a diamond blade in a 4" grinder.
Before you agree the job check how flat the walls are with a decent straight edge or you're heading for real trouble :wink:
Inky Pete
Has thanked: 12 times
Been thanked: 161 times
Re: 1m long tiles
Post by Inky Pete »
Yeah, any unevenness at all in the walls and at that size they're going to kick out like you wouldn't believe.
Best of luck!! :salute:
vanduara37
Re: 1m long tiles
Was thinking just giving it a bodyswerve but hate admitting defeat :boxing:
Rookery
Been thanked: 19 times
Re: 1m long tiles
Post by Rookery »
At this length, the tiles are likely to have a bow in them making it even harder to avoid lipping, especially if fixing brickbond. Put 2 tiles face to face and check. Sounds like these are expensive tiles so if you're going to use a grinder, practise first on some cheap tiles.
Has thanked: 735 times
Been thanked: 2340 times
Re: 1m long tiles
theres challenges and theres disasters waiting to happen and four tiles across a room mmm not good :lol: :lol:
vanduara37
Re: 1m long tiles
The way i see it she has to get someone to do this job, the family put a lot of work my way so should i shirk it or get a doctor to prescribe me a load of Prozac and get on with it. :cb
Inky Pete
Re: 1m long tiles
Post by Inky Pete »
If you've got doubts about it and aren't sure you'd be able to produce a finish you'd be proud of yourself with these materials, then it probably wouldn't be a good idea to put your reputation with a valued customer on the line.
If you don't have the correct tools to cut such large format tiles accurately, then there's your get out. Show them pictures of some big expensive overhead wet cutters and explain that its a more speciallist job than you are equipped for.
These users thanked the author Inky Pete for the post:
vanduara37
Crooksey
Been thanked: 72 times
Re: 1m long tiles
Post by Crooksey »
Get a coal chisel and some gripfill and man up! :lol:
Only joking, I would pass this on to someone else, maybe as they are a good customer you could "project manage" the job so they are still effectively dealing with you.
Beachcomber
Has thanked: 28 times
Been thanked: 71 times
Re: 1m long tiles
Post by Beachcomber »
Simple really - a customers house is not the place to learn new skills!
Knowing your limits saves you hassle and your customers upset and extra cost. It also keeps your rep intact!
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Re: 1m long tiles
Post by m3 fitter »
Large format tiles are not easy at the best of times to fix, they are dependant on the substrate. You don't mention what the tiles are, but i suspect they are porcelain, you can hire a Rubi TX1200 from most decent indepent tile shops and some hire shops. To be honest this is a project to be handled by a tiler with plenty of experience and knows the potential pitfalls. Good luck if you go ahead :wink:
