Jagged edges, help needed.
rotciv
Has thanked: 11 times
Been thanked: 18 times
Post by rotciv »
I am trying to design a catalogue on Publisher 2007. I open images in Photoshop7 and with the pen tool cut around them to make the background transparent. The problem is that when i save them in .gif format,to import them into publisher, the edges sometime look untidy and jagged whilst they were ok in photoshop. Is there a way i can solve this problem? (the images i have have resolution a bit on the low side. I've tried some things suggested on the internet but with no success, ::b
Dreams contain the seed of success..... (if you manage to wake up.)
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: Jagged edges, help needed.
Post by kellys_eye »
You can (in some programs) increase the resolution of pictures. Pixelation will 'always' happen but starting with a higher number means less visibility.
Change them up to the highest your software can do, cut them, then resize them back to what you want.
rotciv
Post by rotciv »
kellys_eye wrote:You can (in some programs) increase the resolution of pictures. Pixelation will 'always' happen but starting with a higher number means less visibility.
When you say some programs can increase the resolution of pictures, can photoshop do that? Or is it done with some other software? If it can, can you please explain step by step how i can do it as i am just a novice in this. thanks.
kellys_eye
Although it's relatively straightforward, this pdf document shows it in the full details which is probably better than I can do....
http://www.creativepro.com/files/story_ ... ageres.pdf
These users thanked the author kellys_eye for the post:
rotciv
tooltraderdirect
Has thanked: 2 times
Post by tooltraderdirect »
Try formatting as a transparent 8 bit png instead. Make sure the resolution of the photoshop image is the same as the publisher destination before importing.
rotciv
Post by rotciv »
tooltraderdirect wrote:Try formatting as a transparent 8 bit png instead. Make sure the resolution of the photoshop image is the same as the publisher destination before importing.
Pls bear with my lack of knowledge, but how would you go about formatting as a transparent 8 bit png. with Dave's method the edges seemed much better but still if i can improve them I'll be really glad.
tooltraderdirect
Usually you will find this in "save as" - and one of the options in the drop down box should be .png. You may have an additonal option to choose 8 bit png instead of the default 32bit.
You could also select the background using the magic wand and then press delete (you can choose the "tolerance" - sensitivity level of this tool). Or you could use the paint bucket tool to choose the same background colour as the document you are pasting into (also has a tolerance slider)
rotciv
Post by rotciv »
Thanks for the info, saving as png seems to be much better than saving as i was doing in .gif format. and at last i managed to locate where i can change an image to 8 bit format. you have all been such a great help. thanks again.
Return to “Computers”
