staircase update...
fixed-it
staircase update...
Post by fixed-it »
staircase-t16632.html
Hi all,
Been a while since Ive been one here!
Thought I'd post a pic of how my stairs look since its been decorated. Original thread link above.
Left the lining, ceilings and wallpapering to the decorator.
Ive replaced all woodwork with new - thats skirting, picture rails, architrave and window sills and flooring.
Built the big cupboard for storage and meters (will post a new thread for that) and the small cupboard under the stairs is the 'cat cupboard'. Still needs a couple coats of paint and handle putting on.
Cat cupboard has another cat flap through the outside wall - this was the only place we could put it.
ant
decorated stairs.jpg (205.55 KiB) Viewed 3013 times
speed
Has thanked: 35 times
Been thanked: 257 times
Re: staircase update...
Post by speed »
looks loads better than before, a new plug socket will finish it off nicely :salute:
fixed-it
Post by fixed-it »
Thanks speed.
Yeah got new chrome sockets and switches to go in and chrome cupboard handles too.
Elite Property Care
Post by Elite Property Care »
Hmm crisp.. :salute:
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Stairs and cupboard look good. nice individual use of the space.
Hopefully gas board etc will have no trouble changing meter over if they see fit!
Has thanked: 734 times
Been thanked: 2336 times
stunning job well done
not sure if the bottom off the stairs will be classified as a landing :dunno:
royaloakcarpentry
big-all wrote:stunning job well done
It is a bit naughty but then again they can obviously live with the restricted access. potential buyer when they come to sell, will be able to rip it out quite easily to leave proper width at bottom of stairs.
fixed-it
Post by fixed-it »
Thanks guys.
Never thought about the space at the bottom of the stairs. House was built in 1937 and as far as I know, and from seeing other houses on the estate, there has always been a cupboard at the bottom of the stairs.
Space at the bottom measures 55cm from front of bottom step to cupboard. Im sure I've left plenty of room for gas and electric. Will post the in-progress pics tomorrow.
fixed-it
Post by fixed-it »
This post was originaly an update on the stairs due to the dislike of the original wallpaper!
I posted a new topic for the cupboard.
If you want to see the cupboard with some in progress pics have a look at this post...
post340839.html#p340839
thanks for looking :thumbright:
a landing area is defined as at least a square the tread width
the regs also say a sphere 100mm across must not pass through any part off the stairs or banisters and lots off people flout that reg
it may or may not be picked up when you sell i personally wouldn't worry
the comment was more to let people know it is covered by regs
Return to “Show Case Gallery”
