Hinge Problems
Locked
thebeesnees
Hinge Problems
Post by thebeesnees »
Hi
Recently bought some Hettich soft-close hinges for my kitchen doors. My fitter said he couldn't use them because they have oval protrusions (see pic) that would require him to drill out doors.
Are they only meant to be used with a certain type of door or is it normal to drill doors?
If I choose to use them is there an easy way to install them, a template perhaps?
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Re: Hinge Problems
Post by Colour Republic »
They are a quick fit hinge which work via clamping, they would require extra holes for the locating lugs.
So your fitter is right.
It's a toss up between your fitter charging you slightly more to fit them or just buying some new hinges.
depends on how many doors you have which will determine the extra cost
Roly
Has thanked: 1 time
Re: Hinge Problems
Post by Roly »
Hi, wouldn't you fit this type of hinge to veneered chipboard doors or MFC doors? Something is rattling around in my head from the past is all.
Roly
thebeesnees
Re: Hinge Problems
Would chipboard/MFC doors still require drilling? My doors are B&Q gloss slab jobbies. Don't really fancy drilling 4 oval shaped holes in every door! Doesn't sound so 'quick-fit' to me! Guessing german doors are pre-drilled - oh well, my bad. :oops:
Roly
Has thanked: 1 time
Re: Hinge Problems
Post by Roly »
The type of hinge you have crush in with clamps as Colour Republic said. I'm not too sure if it would crush so well into MDF its quite hard you see, whereas chipboard is soft ish.
Roly
Colour Republic
Re: Hinge Problems
thebeesnees wrote:Would chipboard/MFC doors still require drilling? My doors are B&Q gloss slab jobbies. Don't really fancy drilling 4 oval shaped holes in every door! Doesn't sound so 'quick-fit' to me! Guessing german doors are pre-drilled - oh well, my bad. :oops:
I take it you have bought undrilled replacement doors?
In which case yes 35mm holes would still need to be drilled for the main body of the hinge but it's these further two lugs that also could do with being drilled. That said depending on the door construction once screwed the lugs will sometimes dig into the door without the need for drilling
thebeesnees
Re: Hinge Problems
Just checked, doors are chipboard with 35mm holes pre-drilled - will see if I can persuade them to fit. If not I have 20 x not-so-quick-fit soft closing hinges for sale!!
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Hinge Problems
Post by royaloakcarpentry »
If they are compatible to the hole size already in the door, then all the fitter has to do is drill 2xholes for the lugs..............he is either lazy, can't be bothered or isn't interested in another £40 on the job.
It is only simple marking out...................Then again, there are kitchen fitters, kitchen bashers and carpenters.
Loosenup
Has thanked: 3 times
Been thanked: 8 times
Re: Hinge Problems
Post by Loosenup »
I agree with ROC.. any fitter worth his salt would do this blindfolded and for just a small charge.. It is not quick to do all the marking out but once the measurements are worked out s'easy. :thumbright:
Has thanked: 825 times
Been thanked: 3574 times
Re: Hinge Problems
If you are not happy with those hinges you can buy Blum soft close which will fit the doors perfectly. I use this firm which give a good price http://www.ddfcomponents.com/categories ... oryid=1370
fin
Has thanked: 32 times
Been thanked: 807 times
Re: Hinge Problems
Post by fin »
ive also used the above firm. super fast delivery last time i used them
Locked
Return to “Kitchen Fitting”
