CD-ROM DRIVE
oneotu
Has thanked: 66 times
CD-ROM DRIVE
Post by oneotu »
Hi
Complete novice I hope someone can help. My computer information tells me that I have not got a CD-ROM DRIVE INSTALLED!
and yet I have a Optiarc DVD-RW AD-72405 on previous hardware information printouts. When I put a CD/DVD in it does not load and it does not show when I bring up my computer, I hope someone can make sense of what I"am attempting to explain? ::b
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: CD-ROM DRIVE
Post by kellys_eye »
Sounds like the cable has dropped out of the back of the CDROM unit - open the box and ensure all connectors are properly in place.
oneotu
Re: CD-ROM DRIVE
Post by oneotu »
Hi thanks Dave for taking the time to reply,
but when I put disc in the light flickers on the unit as though it would load then nothing!
chat_to_rich
Been thanked: 45 times
Re: CD-ROM DRIVE
Post by chat_to_rich »
If all the cables are correct try running this http://support.microsoft.com/mats/cd_dv ... lems/en-us I've seen this problem a few times before and changing the registry upper and lower filters value usually fixes it. The link is to an automated fix.
These users thanked the author chat_to_rich for the post:
oneotu
oneotu
Re: CD-ROM DRIVE
Post by oneotu »
HI. Thanks for your time. Have downloaded the automated fix you reccomended, it has sorted some problems but it cannot detect the CD/DVD DRIVE and the problem still exists.
I can put a disk in the tray and it takes it in and light flashes but does not load and does not register when I click on my computer? The tray comes in and out no problem ::b
Maxsys
Has thanked: 1 time
Been thanked: 5 times
Re: CD-ROM DRIVE
Post by Maxsys »
The power and the data cables are probably separate, so if you have power it will open/shut and take a disc, but no data and it will not read it. Take the side off and make sure the data cable is fully pushed in, it is a large black connector on a ribbon cable, or and IDE connection.
You can see a pic of what i am talking about [http://bit.ly/wdMMeJ]HERE[/url]
These users thanked the author Maxsys for the post:
oneotu
oneotu
Re: CD-ROM DRIVE
Post by oneotu »
Hi Thanks once again,it now loads and plays the disc but have no sound! Help again please
Am also getting pop up window from DELIVERY MANAGER SERVICE stating it has encountered a problem and has to close. This comes quite often, keep sending error report to microsoft but keeps happening.
Maxsys
Has thanked: 1 time
Re: CD-ROM DRIVE
Post by Maxsys »
OK there are obviously some issues with your PC, so be totally honest and tell us when the problems started and what you did before the problems started, i assume this all worked up to a point and then stopped working.
Things to think about are new software installed, new hardware added, any updates you have applied, have you moved the PC have you disconnected any cables and reconnected, and lastly what make and model is the PC?
chat_to_rich
Re: CD-ROM DRIVE
oneotu wrote:Hi Thanks once again,it now loads and plays the disc but have no sound! Help again please
Just done a quick search for the delivery manager service and found this which you may want to take a look at http://www.pcdoctor-guide.com/wordpress/?p=2452
With the sound issue, can you hear all the other sounds on your PC and has sound ever worked from the CD-ROM? Check all the volume settings in the application and from Control Panel to make sure nothing's turned down low or muted. Do you have an older CD-ROM drive with a sound cable? See here for details http://www.computerhope.com/issues/ch000213.htm
Return to “Computers”
