I know that adhesive says 24hrs before grouting but I really need to get it done in a hurry.
What's the shortest I could leave it and what are the consequences of grouting over not-set adhesive??
It's flexible adhesive and grout by the way if that makes a difference.
Cheers
Need to grout quickly
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
It depends entirely on the adhesive, for example if using Bal single part flexible there is no way the adhesive will set by the end of the day, Rapidset with say a bed thickness of 3 or 4mm will be OK to grout after a couple of hours.
Ready mixed can go off a lot quicker than a single part although a lot has to do with size of tiles, the bigger the tile the longer adhesive needs.
Also the tile and wall material has a lot to do with drying times, a porcelain tile on a tanked wall will take a while to set.
