Tiling directly onto brick or add aquapanel
edengarden
Has thanked: 4 times
Post by edengarden »
Hi
I need to add a shower into a room. The two side walls will be completely new, so will be built from studwork and aquapanel. The backwall is currently a bare brick wall, which is beautifully laid with clean, sound, dry bricks. (It is external cavity wall if that makes any difference). Can I tile directly to brickwork or should I aquapanel the back too?
Thanks in advance.
Stan
edengarden
Re: Tiling directly onto brick or add aquapanel
Anyone :help:
Julian Cassell
Has thanked: 11 times
Been thanked: 55 times
Post by Julian Cassell »
I'm sure you 'can' tile brick but, personally, I'd aquapanel it mate. :scratch: Don't think you can just dot and dab it - so I'd mechanically fix as well. If the whole enclosure is aquapanel, you're just not going to get any problems :thumbleft:
Has thanked: 820 times
Been thanked: 3521 times
I would also go with Aquapanel. Have a look at this http://www.teachmediy.co.uk/NetsiteCMS/ ... panel.html
:thumbright:
These users thanked the author dewaltdisney for the post (total 2):
rootedengarden
Rating: 14.29%
edengarden
Thanks for your comments - much appreciated. Looks like more aquapanel then.
Stan
