Deleted
chat_to_rich
Been thanked: 45 times
Re: Deleted
Post by chat_to_rich »
I recently built something similar to the attached spec. I'm not sure about your budget, but it's a starting point for a discussion. I'm sure everyone will have their own opinion! As you don't do gaming you can use the graphics and sound that are onboard the CPU and motherboard. The OS and applications can run from the SSD for greater speed and your documents etc. can be stored on the two 1TB disks in RAID 1 for redundancy. That way if a disk fails you don't lose your data. You still need backups as it doesn't help you if you delete something/get corrupt files.
Are you sure you want to go down the build your own route? I'd normally recommend buying a pre-built model with support etc.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: Deleted
Post by thescruff »
I don't have budgets Rich :oops:
I'd love to go down the build my own road, and would want the best possible, for reliability as much as anything.
Whether I have the skill is another question.
root
Has thanked: 168 times
Been thanked: 173 times
Re: Deleted
Post by root »
:thumbright: you will be fine Scruff if you have ever used meccano you can build a PC :wink:
I would go for off board gfx and a core i7 to make video editing ripping and burning better, converting from divx to dvd and back is a pain and time consuming.
- Dave
thescruff
Re: Deleted
Post by thescruff »
You have to explain things like off board gfx
What I would need is a Dummy list of compatible parts that either one of you guys can supply or I can order
root
Re: Deleted
Post by root »
off board:
on board:
- Dave
root
Re: Deleted
Post by root »
It's difficult to come up with a list of parts.. a lot of it is down to personal preference and unconcious loyalty to certain manufacterers in my experience
- Dave
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Re: Deleted
Post by BillyGoat »
The benefit of off board VGA is that it usually has it's own dedicated memory. Onboard is called discreet video and (mostly) shares it's memory with the system. So, if you had 4GB of system RAM, it's possible that on-board VGA might use 512-1GB of that for buffering and performance.
A dedicated card has it's own memory, usually MUCH faster too. The downsides are:
a) cost
b) noise - if it's got it's own fans, cheap cards save cash here
c) space, in some cases - they can be quite chunky/big
I'd go seperate, if you do video. The name escapes me, but nVidia have a solution that can encode DVD/Video and it completely offloads to the VGA card and is stupidly fast - but an i7 is going to be no slouch either!
BG
root
Re: Deleted
Post by root »
cuda or coda? also elemental....
http://www.porthale.co.uk/products.asp?partno=FY949AA <- nvidia's lowest high end solution :-)
- Dave
thescruff
Re: Deleted
Post by thescruff »
So is all this stuff compatible with each other and where's the best outlet
root
Re: Deleted
Post by root »
most stuff is compatible as long as you get the right speeds and have the right ports on the motherboard.....
I will create a shopping list of a system I want to get and post it up in a bit :-) just gotta go put some more bits in a rack and stab myself with a screwdriver again :-)
- Dave
BillyGoat
Troll Headbutter
Re: Deleted
Post by BillyGoat »
I'm a little bit behind with models at the mo, but will try and help when I can. Be interesting to see what Root comes up with.....I like the other system mentioned earlier as a good base.
I'm quite cheap....I tend to build what I'm given 'as samples'. Beggers can't be choosers and all that! :D
chat_to_rich
Re: Deleted
If you're transcoding video, the Quick Sync technology of the new Core processors is faster than a dedicated graphics card. Take a look here http://www.anandtech.com/show/4083/the- ... 0-tested/9 and here http://www.tomshardware.com/reviews/san ... 833-5.html You'll need a copy of Cyberlink’s Media Espresso 6 or Arcsoft’s Media Converter 7.
root
Re: Deleted
Post by root »
Im with you on that one BG I have had so much redundant equipment that i am a bit loathed to buy stuff now a days :lol:
- Dave
BillyGoat
Troll Headbutter
Re: Deleted
Post by BillyGoat »
Rich could be the saviour......no pressure Rich!
root
Re: Deleted
Post by root »
woah... too expensive for me...
not sure i got as good a system as i could for the price either :sad:
- Dave
Return to “Computers”
