nope should be free ware...
the app should give you a list like this.
The rule is to disable non-Microsoft context menu handlers *one-by-one* and verify if the problem is solved. If disabling one does not solve the problem, undo the disabled item and disable the next non-Microsoft handler. Do the same until the problem is solved and finally identify the culprit. Scroll right to see the Company Name column in ShellExView.
http://www.nirsoft.net/utils/shexview_setup.exe
NOTE: It's not always the Context menu handler, but a PropertySheet handler or an Icon Handler may be the culprit sometimes.
if all else fails try running sfc /scannow to fix the problem, although this will take about 45mins to an hour to run on some systems.
pc has become very slow
- root
- Has thanked: 168 times
- Been thanked: 173 times
Re: pc has become very slow
- These users thanked the author root for the post:
- southwood3
- Dave
- Lemming
- Has thanked: 38 times
- Been thanked: 43 times
Thanks. I didn't get anything like you've posted so will try it again.root wrote:nope should be free ware...
the app should give you a list like this. The rule is to disable non-Microsoft context menu handlers *one-by-one* and verify if the problem is solved. If disabling one does not solve the problem, undo the disabled item and disable the next non-Microsoft handler. Do the same until the problem is solved and finally identify the culprit. Scroll right to see the Company Name column in ShellExView.
- root
may have downloaded something else and not the app websites seem to be very good at misleading people from the actual application you are looking for.
- southwood3
- Dave
- Lemming
root wrote:may have downloaded something else and not the app websites seem to be very good at misleading people from the actual application you are looking for.
Bingo! After disabling and enabling loads on the list I finally got to this one:
Express Zip File Compression Software Yes Context Menu No No No No No No C:\Program Files\NCH Software\ExpressZip\ezcm.dll {8EEA165E-0B8B-4BA7-9796-50214C767171} 26/04/2011 10:26:22 26/04/2011 10:26:23 No *, .cab, .rar, .zip, Folder A 768,512 No
......and the problem has now gone. Many thanks Dave. This has been bugging me for ages.
- CLOSED ACCOUNT
- Has thanked: 871 times
- Been thanked: 757 times
Its a Dell Dimension 5100, Pentium 4, 0.99 GB RAM and its on Windows XP. The Pc is around 5 yrs old.Maxsys wrote:Check this first http://www.bleepingcomputer.com/forums/topic87058.html, also what PC is it, make model, RAM installed and OS.
