Deleted
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Re: Deleted
Post by dave.m »
Hi John,
You can do the first two parts with your old computer before you try to connect the new one.
Part 1
To reset the hub to factory settings, follow the instructions in this forum.
http://tinyurl.com/69c3p7j
You will need a straightened paper clip or a pin to push into the reset hole. Picture of where it is is on the forum.
You need to shutdown the hob and leave the power off for a minute then push the clip in the reset hole and hold it whilst turning the power back on, it should take about 30 seconds and all the lights turn blue. Once the lights have turned blue it will then restart itself.
The default username and password is
username = admin
password = changeme
Part 2
Once you are there you can then set a new password by following instructions here:
http://tinyurl.com/6fhw56x
Part 3
This is how to set up your new computer BUT with Windows 7 it may do most of it automatically, by offering popups to say that it has found a network and letting you click on the one that is yours.
It may want the ask for the info that is on the back panel of the hub, but just follow these instructions and you should be there.
http://tinyurl.com/6egr4vf
dave
But you cannot tell him much.
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: Deleted
Post by thescruff »
Make sense Dave.
The reset is on the back above the on/off switch.
I'll try a pic in a sec.
thescruff
Re: Deleted
Post by thescruff »
How about that, they could do with a good pic on the forum link you posted. :thumbright:
hub reset.jpg (120.2 KiB) Viewed 1323 times
dave.m
Re: Deleted
Post by dave.m »
If you don't post for the next few days, I will know it didn't work. :lol: :lol: :lol:
dave
thescruff
Re: Deleted
Post by thescruff »
I plug the Linksys in direct and hard wire. :mrgreen:
Need another 39 posts by the 11th so can't be off for too long.
root
Has thanked: 168 times
Been thanked: 173 times
Re: Deleted
Post by root »
wireless password on virgin superhubs are usually printed on the back of them :-)
- Dave
Return to “Computers”
