Hidden access panel for tiled bathroom wall
- Has thanked: 54 times
- Been thanked: 23 times
good moaning!
I need to mount some pumps and flow sensors in the new bathroom build. I will make an enclosure in the same boxed wall for the concealed toilet cistern for them.
however they need to be accessible.
what is the best way to make an accessible panel that will be tiled? I want it to look like it is not there
Have seen KeKu clips? any good?
or I do recall seing some sort of flush magnet system?
what do you guys reccomend?
thanks
Dave
thanks
Dave
- root
- Has thanked: 168 times
- Been thanked: 173 times
Re: Hidden access panel for tiled bathroom wall
manthorpe flush magnet systems look good like these: http://www.manthorpe.co.uk/Building/Pro ... Panel.html
- These users thanked the author root for the post:
- davemulheran
- Dave
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Colour Republic did a bathroom and discussed briefly access another-little-bathroom-t34668.html from Schluter (forgive spelling) near bottom of the page.
Hope that you can access the link ok.
- These users thanked the author nick200 for the post:
- davemulheran
Nick
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Why not put them in the cupboard with the cylinder as discussed.
Thanks guys, ive just bought these
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0560261473
bonded to the back of some tiled marmox board should do the trick!
Hi Scruff, absolutley NO room in the new cylinder location i'm afraid.
- thescruff
So where is it going. No room is not usually a good option.
davemulheran wrote:good moaning!
Going there. The ST universal pump is a bit of a beast!
