It's Arrived!
- chat_to_rich
- Been thanked: 45 times
Re: It's Arrived!
Please could you post a screen shot. I'm not at my machine that has the RAID array at the moment, so this is all from memory.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Re: It's Arrived!
An initialize disk box has drop down
Do I want MBR or GPT
thats master boot record or guid partition table
- chat_to_rich
- chat_to_rich
- chat_to_rich
Re: It's Arrived!
When you create the partion choose quick format. Label the drive as RAID or something obvious.
- thescruff
- thescruff
- chat_to_rich
Re: It's Arrived!
You should see a black bar for the new drive. Right click and choose new simple volume. Go through the wizard, assign a drive letter and quick format. We may need to finish this tomorrow. Hope that's ok.
- chat_to_rich
- thescruff
Re: It's Arrived!
You can finish tomorrow if you wish.
Called itself drive D,
New volume (D) is now showing in the top below C
- thescruff
Re: It's Arrived!
chat_to_rich wrote:Just to be clear, the above instructions are still within Disk Management.
No good telling me after I done it
Drive D say Healthy (primary Partition)
- chat_to_rich
Re: It's Arrived!
Sounds like it's all done - well done!
If you look in Computer you should now see D, which is your RAID drive. Tomorrow I'll post a screenshot for you to compare against so we can be sure it's all setup correctly. Then we can plugin your spare disk and start moving over your files.
- These users thanked the author chat_to_rich for the post:
- thescruff
- thescruff
Re: It's Arrived!
Got a drop down box to say view files in windows explorer. and it shows as new volume 1.81TB
I assume I can close all the open bits now.
- thescruff
Re: It's Arrived!
This post is on the new computer so it still works.
Thanks again Rich.
See you some when tomorrow
Thanks again Rich.
- chat_to_rich
Re: It's Arrived!
Please can you post a screenshot of the Intel Matrix Storage Manager, like the one I've attached to this post. Please can you also post a screenshot of the drives that are visible when you click Start -> Computer. I want to check that everything's setup correctly before we continue.
- RAID.PNG (109.82 KiB) Viewed 1632 times
