Matwell sizes
Rogue
Matwell sizes
Post by Rogue »
Am thinking of fitting a matwell inside the hall at my front door entrance. Floor in hall was going to be solid oak but now going for a heavy duty 12mm laminate. Have some heavy duty kids so that was the major factor in that decision!
What are the standard sizes for matwells and are they a good idea for breaching the step into a laminate floor from outside ?
Had intended to make up a frame so need to know what size it should be. Or would it be better to just leave an ordinary mat over the laminate?
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I'd go for the second option, but would also use some of the anti slip tape to ensure that the mat does not slide ontop of the laminate.
Rogue
Post by Rogue »
Thanks UHM.
Just realised second option might stop my front door from opening due to the increase in floor height i.e. If I just put a mat on top of the floor then the door clearance will be tight. :cussing:
Only-Me
Been thanked: 3 times
Post by Only-Me »
Topps do matwell edgings.......you cut to size :thumbright:
tim'll fix it
BANNED
Post by tim'll fix it »
you can buy coconut matting at a carpet shop which you can get cut to any size
