This is a difficult question (not like my last question)
- Has thanked: 43 times
This is a difficult question (not like my last question). I hope somebody can solve it for me:
Every time when I start my Vista, there are always two icons I don't like appearing at the bottom right colour of my screen. Can you tell me how to stop them showing up when my Vista start?
- Vista.jpg (10.28 KiB) Viewed 3349 times
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: This is a difficult question (not like my last question)
But you cannot tell him much.
dave.m,
Thank you for response this difficult question!
I have just followed the instruction in the link you suggested but the instruction not worked for me. I guess it is because my problem is from Vista system (from a disk came with my PC), not from other software I installed.
- root
- Has thanked: 168 times
- Been thanked: 173 times
This will get rid of all those annoying litle icons in the systray.
Open up regedit.exe through the start menu search or run box, and then navigate down to the following key (Create if it doesn’t exist):
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Create a new 32-bit DWORD value in the right hand pane with these values:
Value: 1
You will have to logoff and back on for this to take effect....
Value: 1
- Dave
- dave.m
If it is like Windows 7, in the System tray next to those icons, there will be a small arrow head pointing up, click it an dthen click Customise.
Find the icons and select 'Only show notifications' in the drop down menu for each one. Then click OK.
This will stop them showing in the systray unless they have some information for you.
The left icon in your picture is the Safely Remove icon for unplugging USB sticks etc safely after they have been used by Windows.
Not sure what the other one is but if you point at it, a popup should tell you what it indicates.
Why I want to get rid of them:
The icon "Safely Remove icon" causes a lot "Devices with Removable Storage" show up when I click "Start - Computer".
The other icon I don't like is "Blocked startup programs", it may pop up a message "Windows has blocked some startup programs" from time to time.
I will try what you two suggested in a moment.
- root
then you should keep these two as well, i believe one is for your display settings and the other one is an icon for hardware removal as dave.m said...
why do you want to get rid of them?
- Dave
root,
The other icon "Blocked startup programs" may pop up a message "Windows has blocked some startup programs" from time to time.
- dave.m
You must have some hardware plugged in.The icon "Safely Remove icon" causes a lot "Devices with Removable Storage" show up when I click "Start - Computer".
Find out which programs Windows has blocked by clicking the icon to see what the information is.The other icon I don't like is "Blocked startup programs", it may pop up a message "Windows has blocked some startup programs" from time to time.
This will remove all the icons on the desktop systray but they will re-appear if/when the program is running.
How To clear the Past Items or Icons list in the TaskBar, perform the following steps:
1. Start ~ Run type regedit in box ~ OK . Navigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\TrayNotify
2.Delete the IconStreams and PastIconsStream values by right click, choose delete
3.Open Task Manager (Ctrl+Alt+Del) , click the Processes tab, click Explorer.exe , and then click End Process .
4.In Task Manager, click File ~ New Task , type explorer.exe , and then click OK
It will remove all the icons ,but windows puts them back as they are used again. If yours show up again then they are in use so leave them alone.
- dave.m
Do you have a wireless mouse or keyboard? They shouldn't make it show but may do.marktwo wrote:The problem is when I start Vista, nothing to be plugged!dave.m wrote:You must have some hardware plugged in.
Have you found out what Windows prevents from starting, it could be malware and you should run a scan if it is.
Not being funny but what difference does it make to your use of the computer by having a couple of icons in the systray?
They are there for a reason and it is no good just turning them off without finding out what they are there for.
Do you think "Blocked startup programs" may still pop up a message "Windows has blocked some startup programs" bacause when start my PC Vista blocks some startup programs (Vista is in use).dave.m wrote:It will remove all the icons ,but windows puts them back as they are used again. If yours show up again then they are in use so leave them alone.
No, I haven't wireless mouse nor wireless keyboard.
