LONG worktop edging fpr breakfast bars ?
Locked
johnch
Post by johnch »
Does anyone know where I can get metal worktop edging that is long enough to cap the end of a breakfast bar size worktop (~75 cm deep in my case) - the only ones that I can find in Screwfix (eg link below) etc are 62cm long - ie long enough to cap the end of a normal worktop, but not the deper breakfast bar. I know you can get strips of coloured edging to match the breakfast bar surface, but I don't fancy that option because I'm not happy I can cut the worktop well enough for it to look OK ...
http://www.screwfix.com/app/sfd/cat/pro ... 9&id=86915
tim'll fix it
BANNED
Post by tim'll fix it »
use two and have a join
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
Tim might be able to verify this but your problem is the most common thing you hear about when somebody does their own worktops.
unfortunately a one off job doesn't warrant buying a jig and router.
however, i did buy them both about 5 years ago. it has saved me no end of hassle and i have fitted 100's of kitchens and worktops.
i tend to charge about £30 a joint but the other day i bumped into an old m8 of mine that is a joiner, he basically told me all he does is fit worktops now: -
£150 a joint!!!!! :shock: :shock: :shock:
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
£150 a joint!!!!!
Damn expensive tab's them. :shock:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
tim'll fix it
BANNED
jointing bars look gash
I have a jig and use it
for me I price worktops buy the day, but then I will do the whole job, join, fit and put the sink in too
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
The OP's not wanting a joint :sad: he's looking for a metal facing for an unfinished end of a 750mm worktop that he's made into a breakfast bar.
Jaeger.
johnch
Post by johnch »
Allan's right - I'm not looking to join two worktops - I've done that and it looks fine - this is capping the end of a wider than normal (ie breakfast bar) worktop ...
Cheers
tim'll fix it
BANNED
well use two and have a join then
Jaeger_S2k
Pro Handyman
Is that the only fix Tim?
Are the edges not available in other sizes?
If it's the only way, would you mitre the joint?
Jaeger.
tim'll fix it
BANNED
the problem is that john has posted a link for a corner joint when he has asked for a end cap (so lets not talk about mitres anymore)
i have never seen one bigger than 630mm
two cut with a nice square joint would look ok
but then I dont like these type of thing so personally I would fit the edging strip that came with the bar and then trim it with a laminate trimming bit in the router to fit
johnch
Post by johnch »
Ok - thanks everyone.
Locked
Return to “Kitchen Fitting”
