Cheap router table and other tools
- Has thanked: 823 times
- Been thanked: 3563 times
This router table at £30 must be a bargain for those of you who would like to extend the use of your router.
http://www.aldi.co.uk/uk/html/offers/sp ... _20629.htm
There is also a cheap box of cutters worth it for sacrificial jobs that knock them out http://www.aldi.co.uk/uk/html/offers/sp ... _20628.htm
And a cheap belt sander well worth £20 http://www.aldi.co.uk/uk/html/offers/sp ... _20630.htm
And finally some cheap detail and belt sanding sheets http://www.aldi.co.uk/uk/html/offers/sp ... _20631.htm
There are some other good deal too http://www.aldi.co.uk/uk/html/offers/of ... nday11.htm
All from tomorrow
All from tomorrow
- These users thanked the author dewaltdisney for the post (total 3):
- big-all • BRUNO • zedhead
- Rating: 21.43%
- Has thanked: 736 times
- Been thanked: 2341 times
Re: Cheap router table and other tools
nice find dwd
all i would add is if you buy the delta sheets for your bosh 180 multitool or similar check they stick as i had some lidl ones and the velcro is different so the would not stick
- Has thanked: 17 times
- Been thanked: 2 times
I bought the router, it really is cheap. The height adjustment knob on the router broke before even using it. Have to go back and get my money back. The router table and bits are fine.
Shame about the router. Let us know how you get on with the table when you get your router sorted
I ended up fixing my old router, and when clamping it down it seems firm, but when it came to routing a piece on the table I could see some play in the router. I'm guessing the router table only works best with it's own brand of router. I will give it another go tomorrow.
there should be no play[less than say 0.25mm]in the total setup
if you have more movement something is wrong
you often have to drill extra holes to give firm fixings but virtually any router will work with any table the only difference being 1/4 inch and half inch
Did you use machine screws to fix it to the table? Routers have threaded holes for this purpose in the base and sometimes you have to drill extra holes in the table to get the router firmly affixed.
if the table uses clamps then normally that is suffice
can you try and work out where the play is ??
- Deceased 21-10-2011 R.I.P
- Has thanked: 8 times
- Been thanked: 90 times
That router table looks like the B&Q McAllister table.
Useless.
My comments apply to the B&Q so may not apply to this table. Anyway, for the B&Q version you have to demount the router to change the bit. That's cos they've put screens up so your fingers can't get caught under the table. Also setting the height of the bit is very difficult.
I bought a new table. I haven't quite got around to throwing the old table away, so if anyone wants it I'll give tit to them. They can pick it up from Ipswich for free.
Useless.
- Has thanked: 12 times
I bought the table and bits and use them with a Dewalt router. So far only used it to make 5 hardwood newell post caps but it worked fine on them. The table was cheaper than the quote I got from the local wood merchant to make the caps. You can change the bit with the Dewalt fixed to the table but it is a bit fiddly. The router did not move when held by the 4 table clamps but this was not a particularly difficult job.
