Bathroom rebuild - Work in progress
- Has thanked: 1414 times
- Been thanked: 4015 times
Re: Bathroom rebuild - Work in progress
Looks like it's coming along nicely for a weekend project..
- Has thanked: 54 times
- Been thanked: 23 times
Few things done, all epoxy grouted, siliconed. Bath installed.. screen brought up (that was fun)
Towel rail fitted / plumbed / central heating topped back up and bled
- Crooksey
- Been thanked: 72 times
Crooksey wrote:bath waste looks a bit ropey?
ropey in what way? its bone dry. Properly sealed. All correct parts. And drains perfectly.
The original bath waste went in the same run across the floor (but wasnt a stand alone bath and had grey pipe the whole length) , it cannot go under the floor as joists run across its path
(also why I have a pumped waste system for the shower!)
I think it is spot on
- Has thanked: 379 times
- Been thanked: 584 times
Been looking at progress for a while now and it is looking good,just one thing i would change if it is not to late. Is the tails coming out of wall to the chrome towel rail .I would used chrome
they are being painted chrome mate :) dont worry, they arent being left coppertransitboy wrote:Been looking at progress for a while now and it is looking good,just one thing i would change if it is not to late. Is the tails coming out of wall to the chrome towel rail .I would used chrome
Nope!
well there is a downstairs loo... but ive neen nazi showering under the hose in the garden or using the showers at the gym when up town in work.
The missus has NOT been pleased
but we have a running hot bath now! happy days.
also just fitting the loo.
shower is kinda ready but shower screen not fitted yet
- These users thanked the author davemulheran for the post:
- white pan man
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
You have some serviceable bits behind there Dave, what provisions are you making to get at them.
The grohe flush button panel flips down and acts as a service point to inside the cistern
The top of the 'cabinet' is just going to be siliconed so it can be cut and lifted off easily. Giving access to service valve for water supply and cistern internals also
also the side panel will be siliconed the same as the top, Giving access to waste pump/valve.
