Blum hinges - retrofit?
Locked
davemulheran
Has thanked: 54 times
Been thanked: 23 times
Post by davemulheran »
Hi all... does anyone know much about BLUM soft close hinges and drawer runners?
Our kitchen we are refurbing has PONY MFI soft close popper things screwed to the carcases.. they are rubbish!
Do BLUM do a universal hinge assembly with built in soft close mechanisms that will fit?
my hnges are the standard hole in door, hinge semicircle placed in this hole and screwed in. then the two screws to hold the hinge to the carcass.
I also have 2 drawers I would like to make soft close also
would like to renew all for BLUM if poss
viable?
thanks
Dave
Has thanked: 823 times
Been thanked: 3559 times
Re: Blum hinges - retrofit?
Yes, no problem. I use this firm which are good prices Dead link removed by admin
The hinge, plate and soft close come separately and clip together. Get the clip on hinges as these make life easier for hanging. Check your carcase thickness as you need to select the hinge plate to suit the thickness.
As for drawers you will see they do the Blum runners or box kits Dead link removed by admin
If you need a bit more advice give the guy a ring as he is very helpful.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
www.poolewaite.co.uk
They are who I use. Just another option for you.
Being proper architectural ironmongers they do more than cupboard hinges and a lot of the staff hold professional qualifications relevant to the trade.
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
ive ordered the clip on soft closers before from the company dewaltdisney recomended. iirc they delivered the following day so i was well happy.
the company that supplied the kitchen id fitted wanted something like £200 for soft closers. 15 in total. i got them for somewhere in the region of £20 and that all made for one very happy coustomer.
Locked
Return to “Kitchen Fitting”
