Tarting up existing grout
lotstolearn
Has thanked: 16 times
Post by lotstolearn »
Hi
Sorry if I've missed this in another thread it must be a bit of a classic, but can anyone recommend a good product/method for cleaning up dirty mouldy white grout in the bathroom.
In an ideal world I'd cut it out and regrout but it's not bad enough to warrant a big job I'm just looking to freshen up the look. Reviews on grout pens seem to be pretty hit and miss so am thinking try to find a good thick one? Or maybe do a thin layer of normal grout after cleaning off as much as possible on top of the existing and seal?
Any thoughts / advicemuch appreciated!
Alex
Maxsys
Has thanked: 1 time
Been thanked: 5 times
Re: Tarting up existing grout
Post by Maxsys »
Have a look here, lots of good products that do the job. http://uk.hg.eu/wizard-shop/index/id/28 ... om/_toilet also do not try and grout over grout, it will not work, the new grout will crack and fall off. If cleaning does not work then do it properly and remove the old grout and replace. The HG products are very good so if it's not too bad you should be satisfied with the results. Stay away from grout pens, waste of time and money, you may as well use Tippex.
nick200
Has thanked: 409 times
Been thanked: 222 times
Post by nick200 »
I have tried grout pens and some cleaners but ended up removing it with a dremel and a grout removal tool and re-grouting. It took ages but was well worth it.
Try cleaning it first and then see how it is before you decide the next option but I would recommend that you stay clear of the pens!
Nick
Has thanked: 1414 times
Been thanked: 4019 times
Neat bleach, apply with an old toothbrush or similar, leave 20 mins, rinse off...
handyman
Has thanked: 6 times
Been thanked: 11 times
Post by handyman »
lotstolearn
Thanks everyone. Tried neat bleach + toothbrush, pretty good result.
The pics on Craig's link look fantastic though, so will now give the grotbuster a go and compare!
Alex
Maxsys
Has thanked: 1 time
Post by Maxsys »
Now that is impressive, nice one Craig, gonna try that myself
lotstolearn
Ok verdict...neat bleach not bad, but Grotbuster quite a lot more effective. Maybe just the extra thickness and stickiness makes it perfect for grout. Top tip!
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Lotstolearn.......that is probably one of the top tips on the site.
Maxsys
Has thanked: 1 time
Post by Maxsys »
Did my shower on the weekend, could not believe the results, outstanding, that tip should be stickied.
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Post by BillyGoat »
Looks good - like it!
I got fed up of grout, so I've gone over to waterproof lamiated boards - no more grout to clean.
When you compare the installation costs vs tiles - it works out better in my eyes. Less time to install too.
No grout, no joins for water to penetrate and rot, easy to clean, plenty of patterns to choose from.
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
Maxsys wrote:Did my shower on the weekend, could not believe the results, outstanding, that tip should be stickied.
As you wish.
